Home » Newcomers » Newcomers » Eclipse won't download. Application not found
Eclipse won't download. Application not found [message #1692146] Mon, 13 April 2015 19:21 Go to next message
I'm trying to download eclipse for learning java. I try to download the Eclipse IDE for Java Developers Windows 64 Bit, and every time it goes through downloading, and when I open it it says C:\...\eclipse-java-luna-SR2-win32-x86_64.zip Application not found.
Can anyone help?
Re: Eclipse won't download. Application not found [message #1692156 is a reply to message #1692146] Mon, 13 April 2015 23:03 Go to previous messageGo to next message
> Can anyone help?
Read the sticky posts at the top of the forum, please.
Re: Eclipse won't download. Application not found [message #1692276 is a reply to message #1692156] Tue, 14 April 2015 12:57 Go to previous messageGo to next message
Describe in more detail what you're doing. For example, are you trying to open the ZIP file that you downloaded?
Re: Eclipse won't download. Application not found [message #1692310 is a reply to message #1692146] Wed, 15 April 2015 00:56 Go to previous messageGo to next message
Perhaps you're a candidate for downloading and using the new installer?
https://www.eclipse.org/forums/index.php/t/1065514/
Re: Eclipse won't download. Application not found [message #1692431 is a reply to message #1692310] Wed, 15 April 2015 12:53 Go to previous messageGo to next message
Thank you for your replies.
@Russell Bateman: I did read the stickies at the top, none of them corresponded to my problem. Or, am I doing something wrong by asking this question, or should I ask this somewhere else? I'm sorry if I'm doing something wrong.
@Eric Rizzo: Here is exactly what I have done. I downloaded the JDK for 64-Bit already. I am trying to download eclipse from the Windows 64-Bit found at downloads-Eclipse IDE for Java Developers-Windows 64-Bit. It seems to download fine, and takes about 5 minutes to download. It finishes fine, but when I click on it to open it, it shows the message I put in my original post. Am I downloading the wrong thing, not have something I need to download/open it, downloading/opening it wrong or something else?
@Nitin Dahyabhai: I looked at it, but it seems like it isn't finished yet. I'm also a little nervous about installing it that way, and would do it only if it is the only way to do it.
Re: Eclipse won't download. Application not found [message #1692433 is a reply to message #1692431] Wed, 15 April 2015 13:20 Go to previous messageGo to next message
To be honest, this seems like a system problem rather than an Eclipse problem. Eclipse comes in a ZIP file, but it sounds like you can't even open the ZIP file (which Windows has the built-in ability to do). Can you open any other ZIP files on your system?
Re: Eclipse won't download. Application not found [message #1692455 is a reply to message #1692433] Wed, 15 April 2015 17:18 Go to previous message
You are right! I thought I could open one, but when I created a test zip file, and tried to open it , it said the same message. Sorry for having a problem not with eclipse but on my own system though. Thank you, I'll get that figured out.
Previous Topic:EGit Documentation for the JAWS for Windows Screen Reading Software Version 16
Next Topic:How to change Gerrit Username?
Current Time: Tue Jun 03 06:54:50 EDT 2025
Powered by FUDForum. Page generated in 0.29634 seconds
