maven build does not fails on validation error [message #1692245] |
Tue, 14 April 2015 09:51  |
in my project I generate a configuration.
When I use the DSL-plugin in eclipse the errror is marked, but when I run the maven build it does not complain. The parameter <failOnValidationError> seems to be ignored and is always false.
[INFO] --- xtext-maven-plugin:2.8.1:generate (generate-sources) @ chpmhs.emu.bzw ---
[INFO] Encoding: UTF-8
[INFO] Compiler source level: 1.7
[INFO] Compiler target level: 1.7
[INFO] Using common types.
[INFO] Collecting source models.
[INFO] Installing type provider.
[INFO] Starting validation for input: ...
[ERROR] ERROR:Couldn't resolve reference to JvmType ...
[INFO] BUILD SUCCESS
FUDForum. Page generated in 0.03927 seconds
