Home » Archived » Sapphire » "DateTimeBrowseActionHandler" is not a valid Java type name
"DateTimeBrowseActionHandler" is not a valid Java type name [message #1673741] Sat, 14 March 2015 08:54 Go to next message
I have a Sapphire (8.1.2) application running fine with Eclipse Luna. With Eclipse 3.8.2 (unfortunately I need it there), I get a runtime error when opening a file:
Sapphire user interface definition has failed validation. "DateTimeBrowseActionHandler" is not a valid Java type name
	at org.eclipse.sapphire.ui.def.DefinitionLoader$Reference.resolve(DefinitionLoader.java:355)
	at org.eclipse.sapphire.ui.SapphireEditor.createPage(SapphireEditor.java:691)
	at org.eclipse.sapphire.ui.swt.xml.editor.SapphireEditorForXml.createFormPages(SapphireEditorForXml.java:196)
	at org.eclipse.sapphire.ui.swt.xml.editor.SapphireEditorForXml.createEditorPages(SapphireEditorForXml.java:163)
	at org.eclipse.sapphire.ui.SapphireEditor.addPages(SapphireEditor.java:599)
	at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEditor.java:138)
	at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:315)
	at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
	at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
	at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
	at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
	at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
	at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
	at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
	at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
	at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
	at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
	at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
	at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
	at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2955)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2863)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2855)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2806)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2802)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2786)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2777)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:655)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:614)
	at org.bricks.etml.wizards.SampleNewWizard$2.run(SampleNewWizard.java:118)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:173)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:388)
	at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1028)
	at org.bricks.etml.wizards.SampleNewWizard.performFinish(SampleNewWizard.java:70)
	at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
	at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:259)
	at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:279)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
	at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
	at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
In the sdef file I have:
<action-handler>
  <action>Sapphire.Browse</action>
  <impl>DateTimeBrowseActionHandler</impl>
</action-handler>
and DateTimeBrowseActionHandler extends BrowseActionHandler.
What's wrong?
Re: "DateTimeBrowseActionHandler" is not a valid Java type name [message #1679764 is a reply to message #1673741] Mon, 16 March 2015 15:05 Go to previous messageGo to next message
I am not certain what's going on here. Could you try debugging this a bit? Place a breakpoint on the constructor of JavaTypeName and see what happens when it gets to this class.
Re: "DateTimeBrowseActionHandler" is not a valid Java type name [message #1680043 is a reply to message #1679764] Mon, 16 March 2015 17:35 Go to previous messageGo to next message
Seems after adding the org.eclipse.sapphire.osgi.fragment plugin to the dependencies of the feature project, the error is gone.
Strange enough, in the feature.xml file the plugin could not be resolved (error 'Plug-in reference cannot be resolved').
Anyway, many thanks for having a look.
Re: "DateTimeBrowseActionHandler" is not a valid Java type name [message #1692147 is a reply to message #1673741] Mon, 13 April 2015 19:42 Go to previous messageGo to next message
I had the same problem when I install my feature onto a freshly unpacked Luna SR2.
As I checked the installation, I saw that all the expected Sapphire plug-ins were available, but no Sapphire feature. After I installed a Sapphire feature from the update site everything works OK.
I finally fixed it by adding the required Sapphire features to my feature.xml:
   <requires>
      <import feature="org.eclipse.sapphire" version="8.1.0.201411041306" match="greaterOrEqual"/>
      <import feature="org.eclipse.sapphire.osgi" version="8.1.0.201411041306" match="greaterOrEqual"/>
      <import feature="org.eclipse.sapphire.modeling.xml" version="8.1.0.201411041306" match="greaterOrEqual"/>
      <import feature="org.eclipse.sapphire.ui.swt.xml.editor" version="8.1.0.201411041306" match="greaterOrEqual"/>
      <import feature="org.eclipse.sapphire.ui" version="8.1.0.201411041306" match="greaterOrEqual"/>
   </requires>
This solves it for me, but I don't understand why this is needed.
Ralf
Re: "DateTimeBrowseActionHandler" is not a valid Java type name [message #1692265 is a reply to message #1692147] Tue, 14 April 2015 12:01 Go to previous messageGo to next message
The core Sapphire framework doesn't understand OSGi. It expects all Sapphire jars and all client jars in the same system classloader as you would in a traditional Java app. To load components in an OSGi environment, where different bundles have their own classloaders, the org.eclipse.sapphire.osgi.fragment is required. It's included in org.eclipse.sapphire.osgi feature.
Re: "DateTimeBrowseActionHandler" is not a valid Java type name [message #1692272 is a reply to message #1692265] Tue, 14 April 2015 12:51 Go to previous message
Yes, the following addition to feature.xml does it:
   <requires>
      <import feature="org.eclipse.sapphire.osgi" version="8.1.0" match="greaterOrEqual"/>
   </requires>
Previous Topic:Tree-like property editor
Next Topic:Fact not displayed on empty field
Current Time: Tue Oct 28 18:52:01 EDT 2025
Powered by FUDForum. Page generated in 0.04791 seconds
