How to share my work [message #1692078] |
Mon, 13 April 2015 05:28  |
Hello everybody !
Here is my last new questions :
I have to share the work I did with some people that don't know anything about neither UML nor SysML, and they won't install Papyrus to read my files...
How can I export my model from Papyrus to a text document for exemple ?
Is there a way to do it automatically, or should I use a "copy/paste" way ?
Then, I would appreciate any advice about a way to simply present a UML or SysML model to someone that doesn't speak the language and has to give an advice on the work that have been done. The first problem I would see is about the links beetween two diagrams : as an exemple, I really wonder how I could show the links between an IBD and the flow specifications concerning this IBD.
Re: How to share my work [message #1693317 is a reply to message #1693244] |
Thu, 23 April 2015 03:52  |
Hi Quentin!
I use the Save as Image File... function available from the diagram context menu, and save each diagram as a .png, which I then put into a Word or Visio file for presentation. Working this way it's a bit easier to maintain a revision log, since I only work on a certain part of the model at a time. But I would recommend looking into genDoc (had my eye on that tool for a while, but haven't had the time yet to check it out) if you want to generate a new document each time you update the model. Risk is though, your receivers will have information overload from hundreds of diagrams in a single file...
Tomas Sandkvist
FUDForum. Page generated in 0.07345 seconds
