Home » Eclipse Projects » Eclipse 4 » Adding plugin error
Adding plugin error [message #1664056] Tue, 10 March 2015 14:20 Go to next message
Not sure if this submitted correctly the first time. I tried adding a new plugin to eclipse, but got the following error. does anyone know what is wrong?
An error occurred while collecting items to be installed
session context was:(profile=epp.package.cpp, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.egit,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.egit.core,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.egit.doc,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.egit.ui,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.jgit,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.jgit.archive,3.7.0.201502260915-r
No repository found containing: org.eclipse.update.feature,org.eclipse.egit,3.7.0.201502260915-r
No repository found containing: org.eclipse.update.feature,org.eclipse.jgit,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.jgit.java7,3.7.0.201502260915-r
No repository found containing: org.eclipse.update.feature,org.eclipse.jgit.java7,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.slf4j.impl.log4j12,1.7.2.v20131105-2200
Re: Adding plugin error [message #1691119 is a reply to message #1664056] Thu, 02 April 2015 08:31 Go to previous messageGo to next message
That's exactly (!) the error-message i get, when trying to install the smarty-Plugin from p2-dev.pdt-extensions.org
I'm running eclipse-version (very new):
Version: Luna Service Release 2 (4.4.2)
Build id: 20150219-0600
Re: Adding plugin error [message #1691834 is a reply to message #1691119] Fri, 10 April 2015 01:51 Go to previous messageGo to next message
I have the same issue while trying to update.
Eclipse IDE for Java Developers
Version: Luna Service Release 1 (4.4.1)
Build id: 20140925-1800
Re: Adding plugin error [message #1691916 is a reply to message #1691834] Fri, 10 April 2015 08:57 Go to previous messageGo to next message
Sounds similar to https://www.eclipse.org/forums/index.php/t/1026052/
Re: Adding plugin error [message #1691917 is a reply to message #1691916] Fri, 10 April 2015 08:59 Go to previous messageGo to next message
Thank you, Dirk.
I've tried the solution from that thread but it didn't help. Crying or Very Sad
Re: Adding plugin error [message #1692076 is a reply to message #1691917] Mon, 13 April 2015 05:14 Go to previous message
i tried to manually install smarty before, as described in that linked thread, but it didn't work out - i still got (and get) this error ..
Previous Topic:Problem with Product Export
Next Topic:VERY slow m2e build in Mars - 4.5.0 M6
Current Time: Fri Jul 25 22:58:36 EDT 2025
Powered by FUDForum. Page generated in 0.25897 seconds
