Home » Newcomers » Newcomers » not able to install eclipse (i am new in java i want to develope jsp app for that i need eclipse which version should i )
not able to install eclipse [message #1691982] Sat, 11 April 2015 08:09 Go to next message
hi ,
i am new in java i want to develope jsp app for that i need eclipse which version should i dowload ,
i am using window xp and java 1.5 and tomcat 6 please send me links
i have dowloaded eclipse jee lunaSR2-win32-x86_64 but its not working
please help me
Re: not able to install eclipse [message #1692010 is a reply to message #1691982] Sat, 11 April 2015 19:48 Go to previous messageGo to next message
On 04/11/2015 11:27 AM, mona verma wrote:
> hi ,
> please help me
XP? Really?
Okay, here goes...
You will need Eclipse IDE for Java EE Developers (for what you say you
want to do).
I would attempt to download and run Indigo, which was a very solid version.
http://www.eclipse.org/downloads/packages/release/indigo/sr2
That failing, I'm thinking back up further to Helios. It was also a very
solid release:
http://www.eclipse.org/downloads/packages/release/helios/sr2
Best of luck!
Re: not able to install eclipse [message #1692021 is a reply to message #1692010] Sun, 12 April 2015 05:21 Go to previous messageGo to next message
What pre requisites required for this?
Mona Verma
Re: not able to install eclipse [message #1692051 is a reply to message #1692021] Sun, 12 April 2015 23:24 Go to previous messageGo to next message
Juno was the last release supported on Windows XP, and being XP, you probably need the 32-bit version from http://www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/juno/SR2/eclipse-jee-juno-SR2-win32.zip . You should install at least Java 7 for it, preferably the Java SDK.
[Updated on: Sun, 12 April 2015 23:26] by Moderator
Re: not able to install eclipse [message #1692367 is a reply to message #1692051] Wed, 15 April 2015 07:00 Go to previous messageGo to next message
when ever i try to run eclipse.exe file i get error eclipse.exe is not valid win32 application
Re: not able to install eclipse [message #1692370 is a reply to message #1692367] Wed, 15 April 2015 07:25 Go to previous messageGo to next message
Hi Friend,
Thanks for reply ,which image should i choose ??
Re: not able to install eclipse [message #1692405 is a reply to message #1692370] Wed, 15 April 2015 09:33 Go to previous messageGo to next message
On 04/15/2015 05:25 AM, mona verma wrote:
> Hi Friend,
You leave loose ends here. It's hard to help.
First, download the 32-bit package of Juno as Nitin said. Next, explode
the zip file into your filesystem. Then, using information at
https://wiki.eclipse.org/Eclipse.ini, tell Eclipse (in eclipse.ini)
where your JDK is. You will need a JDK not the mere JRE your computer
has if you're going to develop in Java (and it sounds as if that's what
you want to do).
Then, try to execute eclipse.exe.
If you have trouble, tell us what you did exactly.
Hope this helps.
Re: not able to install eclipse [message #1692895 is a reply to message #1692405] Mon, 20 April 2015 09:33 Go to previous message
32 bit Kepler runs fine in my XP. The Java virtual machine is Oracle (Sun) Java SE build 1.7.0_71-b14.
Previous Topic:Eclipse crash
Next Topic:Eclipse won't start, jdk is incompatible
Current Time: Mon Jun 02 16:15:53 EDT 2025
Powered by FUDForum. Page generated in 0.09272 seconds
