Home » Modeling » Papyrus » Attributes not showing
Attributes not showing [message #1692032] Sun, 12 April 2015 09:18 Go to next message
In UML class diagrams, class attributes and methods aren't displayed. Is this a bug?
Re: Attributes not showing [message #1692037 is a reply to message #1692032] Sun, 12 April 2015 11:14 Go to previous messageGo to next message
Try changing your right button menu filtering preferences / drag and
drop them from the Model Explorer.
Ed Willink
> Is this a bug?
Re: Attributes not showing [message #1692097 is a reply to message #1692037] Mon, 13 April 2015 08:24 Go to previous messageGo to next message
Or, new in Mars M5, you can enable automatic synchronization of views
with the model. Either:
* in the Appearance properties, select the 'Synch with Model' option
* in your CSS stylesheet, set the canonical attribute. Something like this:
Class { canonical: true; }
HTH,
Christian
On 2015-04-12 15:14:51 +0000, Ed Willink said:
> Hi
> Regards
> Ed Willink
>> Is this a bug?
Re: Attributes not showing [message #1692099 is a reply to message #1692097] Mon, 13 April 2015 08:26 Go to previous messageGo to next message
Sorry, I meant Mars M6. Or whatever was the latest milestone.
Christian
On 2015-04-13 12:24:34 +0000, Christian W. Damus said:
> HTH,
> Christian
>> Hi
>> Regards
>> Ed Willink
>>> Is this a bug?
Re: Attributes not showing [message #1692138 is a reply to message #1692099] Mon, 13 April 2015 16:48 Go to previous messageGo to next message
Mars M6? Which version is that? I am using Papyrus UML 1.0.2.v20150316134.
Re: Attributes not showing [message #1692152 is a reply to message #1692138] Mon, 13 April 2015 21:56 Go to previous messageGo to next message
It's a milestone (pre-release) build of the upcoming 1.1 release. So,
quite different from the 1.0.2 release build that you have.
Christian
Re: Attributes not showing [message #1692798 is a reply to message #1692032] Sat, 18 April 2015 17:09 Go to previous message
Did you solve this? How did you do it?
Previous Topic:Collaborative work with svn
Next Topic:Adding nested classifiers to a class
Current Time: Thu Jul 24 22:45:03 EDT 2025
Powered by FUDForum. Page generated in 1.11817 seconds
