Home » Modeling » EMF » How to force EMF not to manipulate reference ids
How to force EMF not to manipulate reference ids [message #1691906] Fri, 10 April 2015 08:15 Go to next message
Having the following code I'm loading a BPMN model.
// dummy URI, loading done through input stream
URI uri = URI.createURI("data.bpmn");
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.createResource(uri, "org.eclipse.bpmn2.content-type.xml");
resource.load(contentStream, null);
Saving the resource resource.save(null); manipulates the output and adds data.bpmn# to references:
<bpmndi:BPMNShape id="BPMNShape_StartEvent_1" bpmnElement="data.bpmn#StartEvent_1">
    <dc:Bounds height="36.0" width="36.0" x="162.0" y="182.0"/>
        <bpmndi:BPMNLabel id="BPMNLabel_1" labelStyle="data.bpmn#BPMNLabelStyle_1">
            <dc:Bounds height="15.0" width="68.0" x="146.0" y="218.0"/>
        </bpmndi:BPMNLabel>
</bpmndi:BPMNShape>
Where it looks like this coming from the input stream:
<bpmndi:BPMNShape id="BPMNShape_StartEvent_1" bpmnElement="StartEvent_1">
        <bpmndi:BPMNLabel id="BPMNLabel_1" labelStyle="BPMNLabelStyle_1">
        </bpmndi:BPMNLabel>
</bpmndi:BPMNShape>
Is there a way to force EMF not to manipulate the references?
Re: How to force EMF not to manipulate reference ids [message #1691908 is a reply to message #1691906] Fri, 10 April 2015 08:24 Go to previous messageGo to next message
Flavio,
Don't use a relative URI to load resources. Use an absolute URI. Where
are you expecting "data.bpmn" to actually exist? If it's in the
workspace, use a URI.createPlatformResourceURI with the full path in the
workspace. If it's in the file system, use File.getAbsolutePath() and
then use URI.createFileURI from that result.
> </bpmndi:BPMNLabel>
> </bpmndi:BPMNShape>
> </bpmndi:BPMNLabel>
> </bpmndi:BPMNShape>
Re: How to force EMF not to manipulate reference ids [message #1691912 is a reply to message #1691908] Fri, 10 April 2015 08:38 Go to previous messageGo to next message
Hi Ed,
Thanks for your very fast reply!
Actually I don't want to use an URI at all, since the model is loaded from the input stream (source is a database).
Is there a way to do that?
If not, creating a dummy temp file and using this as URI would solve the issue?
greets
Flavio
Re: How to force EMF not to manipulate reference ids [message #1691913 is a reply to message #1691912] Fri, 10 April 2015 08:44 Go to previous messageGo to next message
Flavio,
Then use a fake absolute URI, dummy:/whatever. Presumably you do a save
passing in an output stream, not as you've shown in your sample code...
On 10/04/2015 2:38 PM, Flavio Donze wrote:
> Hi Ed,
> from the input stream (source is a database). Is there a way to do that?
> the issue?
> greets
> Flavio
Re: How to force EMF not to manipulate reference ids [message #1691935 is a reply to message #1691913] Fri, 10 April 2015 09:53 Go to previous messageGo to next message
Sorry the "resource.save(null);" was wrong I actually use an OutputStream.
I created a small test case, the references are still manipulated but are not "data.bpmn#ID" anymore, now they are "#ID".
		// previously storing the database input stream to dataFile, file looks OK
		InputStream in = new FileInputStream(dataFile);
		URI modelUri = URI.createFileURI("d:/temp/data.bpmn");
		Resource resource = resourceSet.createResource(modelUri, "org.eclipse.bpmn2.content-type.xml");
		resource.load(in, null);
		in.close();
		OutputStream outputStream = new FileOutputStream(dataFile);
		resource.save(outputStream, null);
		outputStream.close();
		// now the file contains #ID as references
Using URI modelUri = URI.createFileURI("data.bpmn"); will result in "data.bpmn#ID" again.
The file "d:/temp/data.bpmn" does not exist.
Is there maybe some save option or hook to handle this?
Thanks for your help
Flavio
Re: How to force EMF not to manipulate reference ids [message #1691943 is a reply to message #1691935] Fri, 10 April 2015 12:16 Go to previous messageGo to next message
Flavio,
Comments below.
> OutputStream.
> file looks OK
Which resource factory ends up creating which type of resource?
Presumably tou're expecting something registered by the BPMN2 project.
The factory should create the right type of resource with the right
options, but that's a BPMN2 question, so probably better to ask on their
forum.
> in.close();
> Flavio
Re: How to force EMF not to manipulate reference ids [message #1692109 is a reply to message #1691943] Mon, 13 April 2015 09:47 Go to previous messageGo to next message
This is the factory class used by BPMN: org.eclipse.bpmn2.util.Bpmn2ResourceFactoryImpl
Here is how the resource is created:
    public Resource createResource(URI uri) {
        Bpmn2ResourceImpl result = new Bpmn2ResourceImpl(uri);
        ExtendedMetaData extendedMetadata = new XmlExtendedMetadata();
        result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTENDED_META_DATA, extendedMetadata);
        result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTENDED_META_DATA, extendedMetadata);
        result.getDefaultSaveOptions().put(XMLResource.OPTION_SAVE_TYPE_INFORMATION,
                new OnlyContainmentTypeInfo());
        result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE,
                Boolean.TRUE);
        result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE,
                Boolean.TRUE);
        result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LEXICAL_HANDLER, Boolean.TRUE);
        result.getDefaultSaveOptions().put(XMLResource.OPTION_ELEMENT_HANDLER,
                new ElementHandlerImpl(true));
        result.getDefaultSaveOptions().put(XMLResource.OPTION_ENCODING, "UTF-8");
        return result;
Can any of those options cause this?
greets
Flavio
Re: How to force EMF not to manipulate reference ids [message #1692111 is a reply to message #1692109] Mon, 13 April 2015 10:02 Go to previous messageGo to next message
Flavio,
I would generally expect a #<id> to appear. But that depends on what
funky things the BPMN2 folks have in their specialized
XmlExtendedMetaData. Is there any reason you should not expect it to
appear as #<id>? In any case, the implementation of this will
determine which save style is used in
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(EObject,
boolean). Again, this is a question best asked on the BPMN2 folks.
> extendedMetadata);
> extendedMetadata);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> return result;
> greets
> Flavio
Re: How to force EMF not to manipulate reference ids [message #1692549 is a reply to message #1692111] Thu, 16 April 2015 08:38 Go to previous messageGo to next message
For the record, this is how I solved it:
	XMLResource resource = (XMLResource) resourceSet.createResource(modelUri, "org.eclipse.bpmn2.content-type.xml");
	XMLResource.URIHandler uriHandler = new URIHandlerImpl() {
		public URI deresolve(URI uri) {
			// make sure references are stored without # URI prefix
			return URI.createURI(uri.fragment());
	resource.getDefaultSaveOptions().put(XMLResource.OPTION_URI_HANDLER, uriHandler);
	resource.load(inputStream, null);
greets
Flavio
[Updated on: Thu, 16 April 2015 09:24] by Moderator
icon14.gif  Re: How to force EMF not to manipulate reference ids [message #1695415 is a reply to message #1692549] Thu, 14 May 2015 07:07 Go to previous message
Smile thanks same problem and proposed solution work out for me as well. Many thanks.
BR,
Bhuvan
Previous Topic:[xcore] No difference with annotation use
Next Topic:XMI instance with HREFs only
Current Time: Sat Jul 26 20:59:27 EDT 2025
Powered by FUDForum. Page generated in 0.06356 seconds
