How to force EMF not to manipulate reference ids [message #1691906] |
Fri, 10 April 2015 08:15  |
Having the following code I'm loading a BPMN model.
// dummy URI, loading done through input stream
URI uri = URI.createURI("data.bpmn");
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.createResource(uri, "org.eclipse.bpmn2.content-type.xml");
resource.load(contentStream, null);
Saving the resource resource.save(null); manipulates the output and adds data.bpmn# to references:
<bpmndi:BPMNShape id="BPMNShape_StartEvent_1" bpmnElement="data.bpmn#StartEvent_1">
<dc:Bounds height="36.0" width="36.0" x="162.0" y="182.0"/>
<bpmndi:BPMNLabel id="BPMNLabel_1" labelStyle="data.bpmn#BPMNLabelStyle_1">
<dc:Bounds height="15.0" width="68.0" x="146.0" y="218.0"/>
</bpmndi:BPMNLabel>
</bpmndi:BPMNShape>
Where it looks like this coming from the input stream:
<bpmndi:BPMNShape id="BPMNShape_StartEvent_1" bpmnElement="StartEvent_1">
<bpmndi:BPMNLabel id="BPMNLabel_1" labelStyle="BPMNLabelStyle_1">
</bpmndi:BPMNLabel>
</bpmndi:BPMNShape>
Is there a way to force EMF not to manipulate the references?
Re: How to force EMF not to manipulate reference ids [message #1691943 is a reply to message #1691935] |
Fri, 10 April 2015 12:16   |
Flavio,
Comments below.
On 10/04/2015 3:53 PM, Flavio Donze wrote:
> Sorry the "resource.save(null);" was wrong I actually use an
> OutputStream.
> I created a small test case, the references are still manipulated but
> are not "data.bpmn#ID" anymore, now they are "#ID".
> // previously storing the database input stream to dataFile,
> file looks OK
> InputStream in = new FileInputStream(dataFile);
> URI modelUri = URI.createFileURI("d:/temp/data.bpmn");
> Resource resource = resourceSet.createResource(modelUri,
Which resource factory ends up creating which type of resource?
Presumably tou're expecting something registered by the BPMN2 project.
The factory should create the right type of resource with the right
options, but that's a BPMN2 question, so probably better to ask on their
forum.
> resource.load(in, null);
> in.close();
> OutputStream outputStream = new FileOutputStream(dataFile);
> resource.save(outputStream, null);
> outputStream.close();
> // now the file contains #ID as references
> Using URI modelUri = URI.createFileURI("data.bpmn"); will result in
> "data.bpmn#ID" again.
> The file "d:/temp/data.bpmn" does not exist.
> Is there maybe some save option or hook to handle this?
> Thanks for your help
> Flavio
Re: How to force EMF not to manipulate reference ids [message #1692111 is a reply to message #1692109] |
Mon, 13 April 2015 10:02   |
Flavio,
I would generally expect a #<id> to appear. But that depends on what
funky things the BPMN2 folks have in their specialized
XmlExtendedMetaData. Is there any reason you should not expect it to
appear as #<id>? In any case, the implementation of this will
determine which save style is used in
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(EObject,
boolean). Again, this is a question best asked on the BPMN2 folks.
On 13/04/2015 3:47 PM, Flavio Donze wrote:
> This is the factory class used by BPMN:
> org.eclipse.bpmn2.util.Bpmn2ResourceFactoryImpl
> Here is how the resource is created:
> public Resource createResource(URI uri) {
> Bpmn2ResourceImpl result = new Bpmn2ResourceImpl(uri);
> ExtendedMetaData extendedMetadata = new XmlExtendedMetadata();
> result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTENDED_META_DATA,
> extendedMetadata);
> result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTENDED_META_DATA,
> extendedMetadata);
> result.getDefaultSaveOptions().put(XMLResource.OPTION_SAVE_TYPE_INFORMATION,
> new OnlyContainmentTypeInfo());
> result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE,
> Boolean.TRUE);
> result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE,
> Boolean.TRUE);
> result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LEXICAL_HANDLER,
> Boolean.TRUE);
> result.getDefaultSaveOptions().put(XMLResource.OPTION_ELEMENT_HANDLER,
> new ElementHandlerImpl(true));
> result.getDefaultSaveOptions().put(XMLResource.OPTION_ENCODING, "UTF-8");
> return result;
> Can any of those options cause this?
> greets
> Flavio
FUDForum. Page generated in 0.31742 seconds
