Home » Eclipse Projects » Lyo » OAuth on DoorsOauthSample
OAuth on DoorsOauthSample [message #1691785] Thu, 09 April 2015 11:46 Go to next message
Hello everybody!
I'm new using Lyo and I'm studying DoorsOauthSample to implement OSLC between DOORS and another application. I'm using DOORS v9.5.1. It works well, but I have a behavior that could not be normal.
When I execute DoorsOauthSample, I always get the following message:
Enter this URL in a browser and run again: http://localhost:8080/dwa/oauth-authorize-token?oauth_token=36746f2a-6bc4-4c78-b97b-98e0548490cb
so, I have to stop my application on line 144 (validateTokens) to enter the given address on my browser, provide my credentials and then I can continue my execution.
If I execute all code, I get two messages
 "Enter this URL in a browser and run again: ..."
and then an error:
SEVERE: null
org.eclipse.lyo.client.oslc.OAuthRedirectException
at org.eclipse.lyo.client.oslc.OslcOAuthClient.getResourceInternal(OslcOAuthClient.java:203)
	at org.eclipse.lyo.client.oslc.OslcOAuthClient.getResourceInternal(OslcOAuthClient.java:220)
	at org.eclipse.lyo.client.oslc.OslcOAuthClient.getResource(OslcOAuthClient.java:113)
	at org.eclipse.lyo.client.oslc.samples.DoorsOauthSample.main(DoorsOauthSample.java:146)
is it this behavior normal?
Thanks for your help
[Updated on: Thu, 09 April 2015 11:46] by Moderator
Re: OAuth on DoorsOauthSample [message #1691853 is a reply to message #1691785] Fri, 10 April 2015 03:53 Go to previous messageGo to next message
It's normal to get the 'enter this URL' message. But I never actually did that. I just wait and on it goes. Nothing manual has to be done. If waiting (by which I mean a few seconds) doesn't help, I'd double check your DWA configuration, in particular all the dbadmin parameters (dwaHost etc)- you could just run them again. Make sure every parameter you set says it is being set. And make sure you are passing in a module as a the parameter, not a project or folder.
Re: OAuth on DoorsOauthSample [message #1691938 is a reply to message #1691853] Fri, 10 April 2015 10:55 Go to previous message
Hi Maeve,
Thanks for your answer. It was my mistake giving the input parameters for DOORSOauthSample. The given address was "localhost" and I configure DWA with my machine name. They have to be exactly the same values given in DWA configuration and DOORSOauthSample.
Previous Topic:HTTP ERROR 500 Problem accessing /OSLC4JStockQuote/stockQuotes. Reason:
Next Topic:Parsing ClientReponse for a DOORS Requirement
Current Time: Sat Jul 26 03:10:15 EDT 2025
Powered by FUDForum. Page generated in 0.05192 seconds
