Home » Modeling » GMF (Graphical Modeling Framework) » Building two editors in one ?
| Building two editors in one ? [message #168927] |
Mon, 21 January 2008 07:07  |
Originally posted by: milan.milanovic.org
I'm planning to build two separate editors which are conected, is it
possible to do with GMF ? These editors should be connected in the
following way, e.g., I want to have UML Class editor and also UML Sequence
editor, but I want to import UML Class editor elements into the UML
Sequence editor (through some drag-and-drop or similar suitable function).
Thanks in advance.
_____________________________
Best regards, Milan Milanovic
| Re: Building two editors in one ? [message #169160 is a reply to message #169046] |
Mon, 21 January 2008 13:37   |
Originally posted by: trommas.yahoo.com
Milan Milanovic wrote:
> O.K.
> Thanks. Is there any tutorial or docs on these three options, or I need
> to learn those from this list archive ?
Diagram Partitioning: http://wiki.eclipse.org/Diagram_Partitioning,
there is also a cheatsheet available (you'll find it somewhere on this
list). Loading Resources is built in, so there's not much to say about
it. Shared Editing Domains is described here:
http://wiki.eclipse.org/GMF_Tips#Sharing_single_EditingDomai n_instance_across_several_diagrams
HTH,
Tomas Zijdemans
> Regards, Milan Milanovic
>>> Hi,
>>> Sequence editor, but I want to import UML Class editor elements into
>>> the UML Sequence editor (through some drag-and-drop or similar
>>> suitable function).
>> There have been many discussions on this (you can search this list).
>> Option 1: Shared editing domain (live update)
>> Option 2: Diagram partitioning (super and subdiagrams)
>> Option 3: Use built-in "Load Resource" fnctionality
>> HTH,
>> Tomas Zijdemans
> O
| Re: Building two editors in one ? [message #169180 is a reply to message #169160] |
Mon, 21 January 2008 17:17   |
Hi Tomas,
great, thank you.
I have one more question, not directly related to this subject. In order
to learn GMF in depth, how much knowledge from GEF, SWT, and simialar
projects do I need ?
>> O.K.
> HTH,
> Tomas Zijdemans
>>>> Hi,
>>>> suitable function).
>>> HTH,
>>> Tomas Zijdemans
>> O
| Re: Building two editors in one ? [message #169218 is a reply to message #169180] |
Tue, 22 January 2008 03:31   |
> Hi Tomas,
> great, thank you.
Interesting question. In my experience I started out thinking I needed
to understand GEF, but I really didn't. Even when implementing lots of
custom figures and "special" graphical artifacts. SWT can be useful if
you intend on implementing a lot of custom GUI (Dialogs etc.). I'd say,
without question, that EMF is the most important project to learn about.
Best Regards,
Tomas Zijdemans
>>> O.K.
>>> need to learn those from this list archive ?
>> HTH,
>> Tomas Zijdemans
>>>>> Hi,
>>>>> it possible to do with GMF ? These editors should be connected in
>>>>> the following way, e.g., I want to have UML Class editor and also
>>>>> UML Sequence editor, but I want to import UML Class editor elements
>>>>> into the UML Sequence editor (through some drag-and-drop or similar
>>>>> suitable function).
>>>> HTH,
>>>> Tomas Zijdemans
>>> O
| Re: Building two editors in one ? [message #169283 is a reply to message #169218] |
Tue, 22 January 2008 09:38   |
btw, is it possible to put something from SWT in a Draw2D figure?
personally I think GEF is as important as EMF. The runtime documentation
of GMF is -just- an addition to the GEF doc. The SWT/JFace in Action
book has the best GEF tutorial in my option. IBMs EMF/GEF Redbook is
good, and free, too.
-stefan
>> Hi Tomas,
>> great, thank you.
>> order to learn GMF in depth, how much knowledge from GEF, SWT, and
>> simialar projects do I need ?
> Best Regards,
> Tomas Zijdemans
>>>> O.K.
>>> this list). Loading Resources is built in, so there's not much to say
>>> about it. Shared Editing Domains is described here:
>>> HTH,
>>> Tomas Zijdemans
>>>>>> Hi,
>>>>>> elements into the UML Sequence editor (through some drag-and-drop
>>>>> HTH,
>>>>> Tomas Zijdemans
>>>> O
| Re: Building two editors in one ? [message #169590 is a reply to message #169283] |
Wed, 23 January 2008 16:28   |
Dear Stefan and Tomas,
thank you very much on these info. Could you (or someone else) tell here
what are suggested steps to learn GMF in depth, is it for example
(knowledge of Java and Eclipse is constant ;-):
1. Learn Eclipse plug-in development (reading Eclipse plug-in creation
book, tutorials, ...);
1. Learn EMF (reading EMF book, tutorials, ...);
2. Learn GEF + SWT (reading that books, etc.);
3. Learn GMF (firstly reading tutorials, ... ?)
Is this path O.K. to you ? Could you, please, update steps in the braces
so that we all know the most efficent way, because there is so much
materials in this area ?
Is it possible to become a commiter to this project, later, because I'm
very interested in it ?
If you want I can ask this question with new subject, because of newcomers
Best regards, Milan Milanović
Ph.D. candidate
The GOOD OLD AI Laboratory
Department of Information Systems and Technologies
Faculty of Organizational Sciences
University of Belgrade
Jove Ilića 154
Serbia
web: http://milan.milanovic.org
> -stefan
>>> Hi Tomas,
>>> great, thank you.
>> Best Regards,
>> Tomas Zijdemans
>>>>> O.K.
>>>> HTH,
>>>> Tomas Zijdemans
>>>>>>> Hi,
>>>>>> HTH,
>>>>>> Tomas Zijdemans
>>>>> O
| Re: Building two editors in one ? [message #169742 is a reply to message #169590] |
Thu, 24 January 2008 11:31   |
I'd say start with EMF, then GMF.
Do the EMF tutorial, then the GMF tutorial.
Use http://wiki.eclipse.org/GMF_Documentation_Index - and this newsgroup
as resources.
HTH,
Tomas Zijdemans
> newcomers ?
> Ph.D. candidate
> Jove Ilića 154
> Serbia
>> documentation of GMF is -just- an addition to the GEF doc. The
>> SWT/JFace in Action book has the best GEF tutorial in my option. IBMs
>> EMF/GEF Redbook is good, and free, too.
>> -stefan
>>>> Hi Tomas,
>>>> great, thank you.
>>> needed to understand GEF, but I really didn't. Even when implementing
>>> lots of custom figures and "special" graphical artifacts. SWT can be
>>> useful if you intend on implementing a lot of custom GUI (Dialogs
>>> etc.). I'd say, without question, that EMF is the most important
>>> Best Regards,
>>> Tomas Zijdemans
>>>>>> O.K.
>>>>> say about it. Shared Editing Domains is described here:
>>>>> HTH,
>>>>> Tomas Zijdemans
>>>>>>>> Hi,
>>>>>>>> is it possible to do with GMF ? These editors should be
>>>>>>>> connected in the following way, e.g., I want to have UML Class
>>>>>>>> editor and also UML Sequence editor, but I want to import UML
>>>>>>>> Class editor elements into the UML Sequence editor (through some
>>>>>>> HTH,
>>>>>>> Tomas Zijdemans
>>>>>> O
| Re: Building two editors in one ? [message #170018 is a reply to message #169742] |
Sat, 26 January 2008 21:44  |
It depends what you want to do. Looking back, I would start learning GMF
by trying to implement my first editor without the generative part of
GMF. You can use the logic example or, for specific situations,
generated code as an example.
Be aware that the generative approach, in my point of view, has some big
design faults:
* abuses the extensible type registry(see gmf-runtime doc).
* they use .ecore as input model, instead of providing a decoration
model to form ElementType hierarchy. Type recognition by constraints
etc. should already be made there.
* The Generator (gmfGen) model doesn't represents the concepts of the
platform (try to extend a specialization type from another
specialization type ;).
* Customization could be done by Decorator models in gmfGen, but
annotating the model and customization of the templates is done at a low
level. It's not possible to decorate the mapping model. Note that it is
not possible to create new files in your templates without modifying the
Generator java class. Code generation is a strange mixture of visitor
pattern + the xPand template language.
* gmfMap to gmfgen model transformation is inflexible if you don't want
to customize hand-coded M2M java code. It is not possible to decorate
the mapping model.
* There is no work flow to customize the generation process.
* no different source folders: Generated code will likely be mixed with
hand written code (ok, you can decorate the gen model and customize the
templates, but this costs more time). This is especially ugly when
changing things in the map, genmodel. Orphaned classes won't be deleted,
sometimes code generation doesn't overwrite classes, so deleting +
regenerating everything is the best option.
* Generated code differs from how normal people would have programmed
the editor, mainly because of design faults at the very beginning of the
editor modeling process.
Honestly, if I had the time, I would start by plain java coding. EMF is
more or less easy, GEF is hard and GMF mainly wraps GEF and adds the EMF
base, a Notation Metamodel, the ExtensibleType registry and all the
extension points in addition to GEF (not easy either). Understanding
this already takes a while and hopefully the generative architecture is
rewritten from scratch or completely redesigned until then :)
This is my option, meant as constructive criticism. Don't get me wrong,
I like code-generation very much and I like GMF (runtime).
-stefan
>> here what are suggested steps to learn GMF in depth, is it for example
> as resources.
> HTH,
> Tomas Zijdemans
>> braces so that we all know the most efficent way, because there is so
>> much materials in this area ?
>> I'm very interested in it ?
>> newcomers ?
>> Ph.D. candidate
>> Jove Ilića 154
>> Serbia
>>> -stefan
>>>>> Hi Tomas,
>>>>> great, thank you.
>>>> implementing lots of custom figures and "special" graphical
>>>> artifacts. SWT can be useful if you intend on implementing a lot of
>>>> custom GUI (Dialogs etc.). I'd say, without question, that EMF is
>>>> Best Regards,
>>>> Tomas Zijdemans
>>>>>>> O.K.
>>>>>>> I need to learn those from this list archive ?
>>>>>> http://wiki.eclipse.org/Diagram_Partitioning, there is also a
>>>>>> cheatsheet available (you'll find it somewhere on this list).
>>>>>> HTH,
>>>>>> Tomas Zijdemans
>>>>>>>>> Hi,
>>>>>>>> list).
>>>>>>>> HTH,
>>>>>>>> Tomas Zijdemans
>>>>>>> O
Current Time: Tue Nov 04 23:31:49 EST 2025
Powered by FUDForum. Page generated in 0.04648 seconds
