Home » Modeling » EMF » Ecore model generator - use tab or white spaces for indentation
Ecore model generator - use tab or white spaces for indentation [message #1691646] Wed, 08 April 2015 13:10 Go to next message
We have a strange behavior, in some workspaces the generated code uses tabs for indentation, in other workspaces it uses white spaces.
We are using the codegen libraries from Eclipse Luna 4.4.1.
Where is this configured? Does it reuse some setting from the Eclipse IDE? Or can I force to use always the same setting when generating the code from the IDE?
I already switched between different formatters in the Eclipse preferences (with tabs only and spaces only) and it has no effect.
[Updated on: Wed, 08 April 2015 13:12] by Moderator
Re: Ecore model generator - use tab or white spaces for indentation [message #1691648 is a reply to message #1691646] Wed, 08 April 2015 13:16 Go to previous messageGo to next message
Am 08.04.2015 um 19:11 schrieb Silvestre Martins:
> uses white spaces.
> no effect.
IIRC., the generator picks up project-specific formatter and cleanup settings (if available). That can lead to different
results in different projects.
Cheers
/Eike
http://www.esc-net.de
Re: Ecore model generator - use tab or white spaces for indentation [message #1691898 is a reply to message #1691648] Fri, 10 April 2015 07:17 Go to previous messageGo to next message
You're right, it seems it uses the formatter settings event if they are not set at the project level (workspace level). My problem was that it was not considering the changes, it seems Eclipse needs to be restarted in order to ensure it refreshes the settings.
It seems the cleanup settings are not used, since I have enabled the "remove unused imports" option and the generated code still have unused imports (this is due to a limitation in our generator templates).
Re: Ecore model generator - use tab or white spaces for indentation [message #1691903 is a reply to message #1691898] Fri, 10 April 2015 07:33 Go to previous messageGo to next message
Am 10.04.2015 um 13:17 schrieb Silvestre Martins:
Have you enabled "Source Cleanup" in your GenModel?
Cheers
/Eike
Re: Ecore model generator - use tab or white spaces for indentation [message #1691934 is a reply to message #1691903] Fri, 10 April 2015 09:52 Go to previous message
Eike Stepper wrote on Fri, 10 April 2015 07:33
No, I haven't. Good hint!
Thanks!
[Updated on: Fri, 10 April 2015 10:24] by Moderator
Previous Topic:Serialisation of EMF-Model to XML file takes several hours
Next Topic:The feature is not a valid feature. (java.lang.IllegalArgumentException)
Current Time: Fri Jul 18 22:23:55 EDT 2025
Powered by FUDForum. Page generated in 0.24523 seconds
