Home » Newcomers » Newcomers » Developing a JAVA FX GUI with Eclipse
Developing a JAVA FX GUI with Eclipse [message #1691313] Sun, 05 April 2015 11:56 Go to next message
Hello
I have eclipse Luna and I need do develop a JAVA FX interface with the scenebuilder or an equivalent. I am a little bit confused about what I need to do.
Do I need to download the JDK 8 or do I need to download the e(FX)eclipse.
Also I am rather new to UNIX and I am running under XUBUNTU 14.04. Presently I have the JAVA 7 Open JDK. Do I take a risk if I replace this JDK by an oracle JAVA 8 JDK?
I thank you for your advice.
Re: Developing a JAVA FX GUI with Eclipse [message #1691315 is a reply to message #1691313] Sun, 05 April 2015 12:06 Go to previous messageGo to next message
On 04/05/2015 09:56 AM, Odile LAMBERT wrote:
> Hello
> need to do.
I'm uncertain, but I think there's a special forum on Eclipse for Java
FX. Ask the first part of your question there.
For the second half...
You risk nothing by upgrading to Java 8, however, my advice is that you
download, to a path like /home/odile/dev/jdk1.8.0, the JDK you want to
use with Eclipse. Leave your the JRE your host depends on alone and let
it continue to update independently as Canonical updates it.
Tell Eclipse, via Window -> Preferences where to find your private JDK.
That way, you're never in doubt as to where you're getting your
development JDK from.
Hope this is helpful.
Re: Developing a JAVA FX GUI with Eclipse [message #1691334 is a reply to message #1691315] Mon, 06 April 2015 03:21 Go to previous messageGo to next message
Thanks a lot for your answer for the second part.
Re: Developing a JAVA FX GUI with Eclipse [message #1691349 is a reply to message #1691334] Mon, 06 April 2015 08:48 Go to previous message
The e(fx)clipse forum can be found on the Forums home page, under the category Eclipse Projects. Here's the direct link: https://www.eclipse.org/forums/index.php/f/259/
Previous Topic:Wildcard import vs static import
Next Topic:Problem installing eclipse
Current Time: Sat Jul 26 23:27:44 EDT 2025
Powered by FUDForum. Page generated in 0.10234 seconds
