Home » Modeling » EMF » EMF Cross platform:/plugin Resource Persistence(Wrong URI references while using platform:/plugin resources)
icon9.gif  EMF Cross platform:/plugin Resource Persistence [message #1691175] Thu, 02 April 2015 15:42 Go to next message
we have two resources. The resource A is contained in a plugin (platform:/plugin/...) and the resource B is stored in the workspace. B contains a reference to A. Using the default generated EMF Editor, the B serialization (xml file) uses the following schema:
href="../../plugin/../"
instead of
href="platform:/plugin/../"
The resourceSet contains both resources and URIs with A and B are ok.
What are we doing wrong?
Thanks for your support
Wink
Re: EMF Cross platform:/plugin Resource Persistence [message #1691176 is a reply to message #1691175] Thu, 02 April 2015 15:47 Go to previous messageGo to next message
Try your scenario with a platform-scheme-aware URI handler in the save
options for your resources. e.g., something like:
Map<Object, Object> saveOptions = // ...
saveOptions.put(XMLResource.OPTION_URI_HANDLER,
new URIHandlerImpl.PlatformSchemeAware());
HTH,
Christian
On 2015-04-02 19:42:13 +0000, Regent LArcheveque said:
> instead of
Re: EMF Cross platform:/plugin Resource Persistence [message #1691178 is a reply to message #1691176] Thu, 02 April 2015 16:03 Go to previous message
It works. Thank you very much.
Previous Topic:Databinding to map entry
Next Topic:read a xml file
Current Time: Wed Jul 23 18:12:00 EDT 2025
Powered by FUDForum. Page generated in 0.02938 seconds
