Best strategy to use for <XML -> Custom-EMF model> [message #1690972] |
Wed, 01 April 2015 06:56  |
I am currently facing the following question:
I have an XSD which defines my XML data structure.
And I have an (existing) Ecore model which defines my custom (target)
EMF data structure.
I now need to read and write XML-files based on the XSD which shall be
represented in the custom EMF model.
I have done searches and found out that there is no out-of-the-box way
to map XSD to a custom Ecore model (correct my if I'm mistaken).
Graphically, there is no way to do this
XML (XSD) <-------[ EMF magic ]------> EMF (Ecore)
So my question now is: does anyone have experience with similar
settings? How did/would you solve this?
Intuitively, I can imagine parsing the XML myself, thus doing this:
XML (XSD) <-------[ custom SAX-based logic ]------> EMF (Ecore)
Or I could generate an intermediate Ecore model for the XSD which does
the XML reading/writing for me, but then I have to create mapping logic
to my EMF model like this:
XML (XSD) <-[ EMF serialization ]-> XSD_EMF (Ecore) <-- ...
... --[ EMF serialization ]-> EMF (Ecore)
Does anyone have an opinion which approach seems better (both in terms
of runtime performance, and in development effort).
Thanks in advance,
Stefan
Re: Best strategy to use for <XML -> Custom-EMF model> [message #1690981 is a reply to message #1690972] |
Wed, 01 April 2015 08:11  |
Stefan,
It's not clear how different those two representations are, so it's hard
to comment... To me generally it seems easier to have two well-defined
Java APIs and write Java code to map instances between those
representations than to write Java code for serializer and deserializer
logic. I doubt performance will be a significant concern either way.
On 01/04/2015 12:56 PM, Stefan Winkler wrote:
> EMF data structure.
> Thanks in advance,
> Stefan
FUDForum. Page generated in 0.04036 seconds
