Home » Eclipse Projects » Eclipse 4 » Unable to update Eclipse to Luna SR2
Unable to update Eclipse to Luna SR2 [message #1649379] |
Wed, 04 March 2015 04:42  |
Hi all,
I am using Eclipse Luna SR1. Since monday, I am trying to update it to SR2 by using the menu Help / Check for Updates. Eclipse shows me the available update to SR2 : Eclipse IDE for Java Developers 4.4.2.20150219-0708
Once the update is started, it aborts a few minutes after with this error message:
Quote:An error occurred while collecting items to be installed
session context was:(profile=epp.package.java, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.egit,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.egit.core,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.egit.doc,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.egit.mylyn.ui,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.egit.ui,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.jgit,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.jgit.archive,3.7.0.201502260915-r
No repository found containing: org.eclipse.update.feature,org.eclipse.egit,3.7.0.201502260915-r
No repository found containing: org.eclipse.update.feature,org.eclipse.egit.mylyn,3.7.0.201502260915-r
No repository found containing: org.eclipse.update.feature,org.eclipse.jgit,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.eclipse.jgit.java7,3.7.0.201502260915-r
No repository found containing: org.eclipse.update.feature,org.eclipse.jgit.java7,3.7.0.201502260915-r
No repository found containing: osgi.bundle,org.slf4j.impl.log4j12,1.7.2.v20131105-2200
Is there a problem with the update site?
Do you have any hint to resolve this problem?
Thank you for your help.
Re: Unable to update Eclipse to Luna SR2 [message #1649491 is a reply to message #1649379] |
Wed, 04 March 2015 05:51   |
Philippe,
The download server has been extremely slow these past days, most likely
with so many people updating, resulting timeouts that kill the
installation process. I've been having the same type of problem...
On 04/03/2015 10:42 AM, Philippe Couton wrote:
> Hi all,
> 4.4.2.20150219-0708
> error message:
> Quote:
>> operand=, action=).
Re: Unable to update Eclipse to Luna SR2 [message #1669171 is a reply to message #1649491] |
Thu, 12 March 2015 16:05   |
... seems to be a more general error as I got similar one for different Eclipse instances, versions, network environments, and OSs (at work and at home):
session context was:(profile=epp.package.dsl, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Does anyone has an idea how to overcome this?
Denis
Re: Unable to update Eclipse to Luna SR2 [message #1694744 is a reply to message #1693561] |
Thu, 07 May 2015 09:59   |
Since Git/EGit has horrible performance for me with Eclipse Luna, I disabled it in my projects. When I try to do Luna update, I would get error:
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.egit,3.7.1.201504261725-r
No repository found containing: osgi.bundle,org.eclipse.egit.core,3.7.1.201504261725-r
No repository found containing: osgi.bundle,org.eclipse.egit.doc,3.7.1.201504261725-r
No repository found containing: osgi.bundle,org.eclipse.egit.mylyn.ui,3.7.1.201504261725-r
No repository found containing: osgi.bundle,org.eclipse.egit.ui,3.7.1.201504261725-r
No repository found containing: osgi.bundle,org.eclipse.jgit,3.7.1.201504261725-r
No repository found containing: osgi.bundle,org.eclipse.jgit.archive,3.7.1.201504261725-r
No repository found containing: org.eclipse.update.feature,org.eclipse.egit,3.7.1.201504261725-r
No repository found containing: org.eclipse.update.feature,org.eclipse.egit.mylyn,3.7.1.201504261725-r
No repository found containing: org.eclipse.update.feature,org.eclipse.jgit,3.7.1.201504261725-r
No repository found containing: osgi.bundle,org.eclipse.jgit.java7,3.7.1.201504261725-r
No repository found containing: org.eclipse.update.feature,org.eclipse.jgit.java7,3.7.1.201504261725-r
To fix, I "disabled" the EGit update from the Eclipse > Preferences > Available Software Sites and now Update worked properly. Just my $0.02
I hope debugging and getting Editor to get to first line of debug works faster.
Re: Unable to update Eclipse to Luna SR2 [message #1730620 is a reply to message #1649379] |
Wed, 27 April 2016 03:36   |
Hi you all,
I have got the same kind of message. I added the available softwares sites in the linked file. When I go to Help > Check for Udate, I get this message after a long time :
No repository found containing: osgi.bundle,minimal-json,0.9.4
No repository found containing: osgi.bundle,minimatch.java,1.1.0
No repository found containing: osgi.bundle,org.apache.axis,1.4.0.v201411182030
No repository found containing: osgi.bundle,org.eclipse.dltk,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.annotations,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.console,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.console.ui,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.core,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.core.index,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.core.index.sql,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.core.index.sql.h2,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.core.manipulation,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.debug,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.debug.ui,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.formatter,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.launching,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.logconsole,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.logconsole.ui,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.testing,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.ui,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.validators.core,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.validators.externalchecker,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.dltk.validators.ui,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.egit.github.core,4.0.3.201509231615-r
No repository found containing: osgi.bundle,org.eclipse.jem.proxy,2.0.500.v201504161518
No repository found containing: osgi.bundle,org.eclipse.jst.common.frameworks,1.1.701.v201509021802
No repository found containing: osgi.bundle,org.eclipse.jst.j2ee,1.1.850.v201506041749
No repository found containing: osgi.bundle,org.eclipse.jst.j2ee.core,1.3.200.v201505041449
No repository found containing: osgi.bundle,org.eclipse.jst.j2ee.web,1.1.850.v201503311656
No repository found containing: osgi.bundle,org.eclipse.jst.jsf.common,1.5.101.v201504022146
No repository found containing: osgi.bundle,org.eclipse.jst.jsf.core,1.7.110.v201504071708
No repository found containing: osgi.bundle,org.eclipse.jst.jsf.facelet.core,1.3.100.v201504071708
No repository found containing: osgi.bundle,org.eclipse.jst.jsf.facelet.ui,1.3.100.v201505112336
No repository found containing: osgi.bundle,org.eclipse.jst.jsp.core,1.2.800.v201505130300
No repository found containing: osgi.bundle,org.eclipse.jst.jsp.ui,1.1.1000.v201505130300
No repository found containing: osgi.bundle,org.eclipse.jst.pagedesigner,1.7.100.v201507242118
No repository found containing: osgi.bundle,org.eclipse.jst.server.tomcat.core,1.1.701.v201508232356
No repository found containing: osgi.bundle,org.eclipse.jst.ws,1.0.750.v201503231435
No repository found containing: osgi.bundle,org.eclipse.jst.ws.axis.consumption.core,1.0.550.v201505131719
No repository found containing: osgi.bundle,org.eclipse.jst.ws.axis.consumption.ui,1.0.800.v201505131719
No repository found containing: osgi.bundle,org.eclipse.jst.ws.axis.creation.ui,1.0.850.v201505131719
No repository found containing: osgi.bundle,org.eclipse.jst.ws.consumption,1.0.800.v201505131719
No repository found containing: osgi.bundle,org.eclipse.jst.ws.consumption.ui,1.1.800.v201504152025
No repository found containing: osgi.bundle,org.eclipse.jst.ws.creation.ui,1.0.900.v201503111711
No repository found containing: osgi.bundle,org.eclipse.jst.ws.jaxrs.core,1.0.600.v201505131719
No repository found containing: osgi.bundle,org.eclipse.jst.ws.jaxrs.ui,1.0.700.v201505131719
No repository found containing: osgi.bundle,org.eclipse.jst.ws.jaxws.core,1.0.402.v201504272018
No repository found containing: osgi.bundle,org.eclipse.jst.ws.jaxws.ui,1.0.401.v201504291921
No repository found containing: osgi.bundle,org.eclipse.jst.ws.jaxws.utils,1.0.301.v201504272154
No repository found containing: osgi.bundle,org.eclipse.jst.ws.uddiregistry,1.0.600.v201505131719
No repository found containing: osgi.bundle,org.eclipse.jst.ws.ui,1.0.500.v201505131719
No repository found containing: osgi.bundle,org.eclipse.m2e.core,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.core.ui,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.discovery,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.editor,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.editor.xml,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.jdt,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.jdt.ui,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.launching,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.lifecyclemapping.defaults,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.logback.appender,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.logback.configuration,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.model.edit,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.profiles.core,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.profiles.ui,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.refactoring,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.scm,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.wtp,1.2.1.20150819-2220
No repository found containing: osgi.bundle,org.eclipse.m2e.wtp.jaxrs,1.2.1.20150819-2220
No repository found containing: osgi.bundle,org.eclipse.m2e.wtp.jpa,1.2.1.20150819-2224
No repository found containing: osgi.bundle,org.eclipse.m2e.wtp.jsf,1.2.1.20150819-2220
No repository found containing: osgi.bundle,org.eclipse.m2e.wtp.overlay,1.2.1.20150819-2220
No repository found containing: osgi.bundle,org.eclipse.m2e.wtp.overlay.ui,1.2.1.20150819-2220
No repository found containing: osgi.bundle,org.eclipse.mylyn.github.core,4.0.3.201509231615-r
No repository found containing: osgi.bundle,org.eclipse.mylyn.github.doc,4.0.3.201509231615-r
No repository found containing: osgi.bundle,org.eclipse.mylyn.github.ui,4.0.3.201509231615-r
No repository found containing: osgi.bundle,org.eclipse.php.core,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.php.core.parser,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.php.debug.core,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.php.debug.daemon,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.php.debug.ui,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.php.formatter.core,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.php.formatter.ui,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.php.help,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.php.refactoring.core,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.php.refactoring.ui,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.php.server.core,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.php.server.ui,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.php.ui,3.6.0.201509151953
No repository found containing: osgi.bundle,org.eclipse.rap.doc,3.0.1.20150708-1759
No repository found containing: osgi.bundle,org.eclipse.rap.tools.intro,3.0.1.20150708-1759
No repository found containing: osgi.bundle,org.eclipse.rap.tools.intro.source,3.0.1.20150708-1759
No repository found containing: osgi.bundle,org.eclipse.rap.tools.launch,3.0.1.20150708-1759
No repository found containing: osgi.bundle,org.eclipse.rap.tools.launch.rwt,3.0.1.20150708-1759
No repository found containing: osgi.bundle,org.eclipse.rap.tools.launch.rwt.source,3.0.1.20150708-1759
No repository found containing: osgi.bundle,org.eclipse.rap.tools.launch.source,3.0.1.20150708-1759
No repository found containing: osgi.bundle,org.eclipse.rap.tools.templates,3.0.1.20150708-1759
No repository found containing: osgi.bundle,org.eclipse.rap.tools.templates.source,3.0.1.20150708-1759
No repository found containing: osgi.bundle,org.eclipse.team.svn.core.nl1,3.0.0.I20150529-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.m2e.sources,3.0.0.I20150529-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.mylyn.sources,3.0.0.I20150529-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.nl1,3.0.0.I20150529-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.nl1.sources,3.0.0.I20150529-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.resource.ignore.rules.jdt.sources,3.0.0.I20150529-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.revision.graph.sources,3.0.0.I20150529-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.sources,3.0.4.I20160131-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.ui.nl1,3.0.0.I20150529-1700
No repository found containing: osgi.bundle,org.eclipse.wst.command.env,1.0.500.v201505131719
No repository found containing: osgi.bundle,org.eclipse.wst.command.env.core,1.0.300.v201505131719
No repository found containing: osgi.bundle,org.eclipse.wst.command.env.ui,1.1.200.v201503231435
No repository found containing: osgi.bundle,org.eclipse.wst.common.emf,1.2.400.v201505132009
No repository found containing: osgi.bundle,org.eclipse.wst.common.frameworks.ui,1.2.400.v201504292002
No repository found containing: osgi.bundle,org.eclipse.wst.common.modulecore.ui,1.0.300.v201505072128
No repository found containing: osgi.bundle,org.eclipse.wst.common.project.facet.ui,1.4.600.v201505072140
No repository found containing: osgi.bundle,org.eclipse.wst.common.uriresolver,1.2.200.v201505132009
No repository found containing: osgi.bundle,org.eclipse.wst.html.ui,1.0.1000.v201505130300
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.core,1.3.401.v201507290128
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.debug.core,3.1.200.v201502261613
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.debug.crossfire,1.0.500.v201505071819
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.debug.rhino,1.0.400.v201503300052
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.debug.rhino.debugger,1.0.500.v201503300052
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.debug.rhino.ui,1.0.400.v201503270022
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.debug.transport,1.0.300.v201502261613
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.debug.ui,1.0.500.v201502261613
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.doc,1.4.101.v201507140011
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.manipulation,1.0.600.v201505071819
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.support.ie,1.0.600.v201505071819
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.ui,1.1.601.v201507290118
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.web.core,1.0.800.v201505130300
No repository found containing: osgi.bundle,org.eclipse.wst.server.core,1.7.0.v201508271522
No repository found containing: osgi.bundle,org.eclipse.wst.server.discovery,1.1.0.v201508271522
No repository found containing: osgi.bundle,org.eclipse.wst.server.preview,1.1.302.v201411112027
No repository found containing: osgi.bundle,org.eclipse.wst.server.ui,1.5.201.v201509022125
No repository found containing: osgi.bundle,org.eclipse.wst.sse.ui,1.3.400.v201505141512
No repository found containing: osgi.bundle,org.eclipse.wst.validation,1.2.700.v201508251749
No repository found containing: osgi.bundle,org.eclipse.wst.ws,1.1.400.v201503231435
No repository found containing: osgi.bundle,org.eclipse.wst.ws.explorer,1.0.800.v201505131719
No repository found containing: osgi.bundle,org.eclipse.wst.ws.parser,1.0.600.v201505131719
No repository found containing: osgi.bundle,org.eclipse.wst.ws.service.policy,1.0.450.v201505131719
No repository found containing: osgi.bundle,org.eclipse.wst.ws.service.policy.ui,1.0.500.v201505131719
No repository found containing: osgi.bundle,org.eclipse.wst.ws.ui,1.1.300.v201503231435
No repository found containing: osgi.bundle,org.eclipse.wst.wsdl,1.2.400.v201505131719
No repository found containing: osgi.bundle,org.eclipse.wst.wsdl.ui,1.2.700.v201505131719
No repository found containing: osgi.bundle,org.eclipse.wst.wsdl.validation,1.1.700.v201505131719
No repository found containing: osgi.bundle,org.eclipse.wst.wsi,1.0.600.v201505131719
No repository found containing: osgi.bundle,org.eclipse.wst.wsi.ui,1.0.600.v201505131719
No repository found containing: osgi.bundle,org.mozilla.javascript,1.7.4.v201504221540
No repository found containing: osgi.bundle,org.sonatype.m2e.mavenarchiver,0.17.0.201502101659-signed-20150525172209
No repository found containing: osgi.bundle,tern.core,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.core,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.jsdt.core,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.jsdt.ui,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.linter.core,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.linter.eslint.core,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.linter.eslint.ui,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.linter.jscs.core,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.linter.jscs.ui,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.linter.jshint.core,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.linter.jshint.ui,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.linter.lint.core,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.linter.lint.ui,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.linter.ui,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.server.nodejs.core,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.server.nodejs.embed.win32.win32.x86_64,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.server.nodejs.ui,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.eclipse.ide.ui,1.1.0.201511082254
No repository found containing: osgi.bundle,tern.server.nodejs,1.1.0.201511082254
No repository found containing: osgi.bundle,ternjs,1.1.0.201511082254
No repository found containing: osgi.bundle,javax.servlet,3.1.0.v201410161800
No repository found containing: org.eclipse.update.feature,org.eclipse.dltk.core,5.3.0.201509040407
No repository found containing: org.eclipse.update.feature,org.eclipse.dltk.core.index,5.3.0.201509040407
No repository found containing: binary,org.eclipse.dltk.core_root,5.3.0.201509040407
No repository found containing: osgi.bundle,org.eclipse.jetty.continuation,9.2.13.v20150730
No repository found containing: osgi.bundle,org.eclipse.jetty.http,9.2.13.v20150730
No repository found containing: osgi.bundle,org.eclipse.jetty.io,9.2.13.v20150730
No repository found containing: osgi.bundle,org.eclipse.jetty.security,9.2.13.v20150730
No repository found containing: osgi.bundle,org.eclipse.jetty.server,9.2.13.v20150730
No repository found containing: osgi.bundle,org.eclipse.jetty.servlet,9.2.13.v20150730
No repository found containing: osgi.bundle,org.eclipse.jetty.util,9.2.13.v20150730
No repository found containing: osgi.bundle,org.eclipse.jetty.webapp,9.2.9.v20150224
No repository found containing: osgi.bundle,org.eclipse.jetty.webapp,9.2.13.v20150730
No repository found containing: osgi.bundle,org.eclipse.jetty.xml,9.2.9.v20150224
No repository found containing: osgi.bundle,org.eclipse.jetty.xml,9.2.13.v20150730
No repository found containing: org.eclipse.update.feature,org.eclipse.jpt.jpa.feature,3.4.2.v201505291546
No repository found containing: org.eclipse.update.feature,org.eclipse.jsf.feature,3.8.0.v201505112336
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.enterprise_ui.feature,3.7.0.v201505131719
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.jsf.apache.trinidad.tagsupport.feature,2.6.0.v201410101748
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.server_adapters.ext.feature,3.3.401.v201508232356
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.server_adapters.feature,3.2.400.v201503102136
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.server_core.feature,3.4.200.v201503102136
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.server_ui.feature,3.4.200.v201503102136
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.server_userdoc.feature,3.3.300.v201503102136
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.web_core.feature,3.7.1.v201509021802
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.web_ui.feature,3.7.1.v201509021802
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.webpageeditor.feature,2.7.1.v201508270443
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.ws.cxf.feature,1.1.203.v201503151903
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.ws.jaxws.dom.feature,1.0.302.v201504272154
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.ws.jaxws.feature,1.2.202.v201504291921
No repository found containing: org.eclipse.update.feature,org.eclipse.jst.ws.jaxws_userdoc.feature,1.0.402.v201503151903
No repository found containing: osgi.bundle,org.eclipse.m2e.archetype.common,1.6.2.20150902-0001
No repository found containing: org.eclipse.update.feature,org.eclipse.m2e.feature,1.6.2.20150902-0002
No repository found containing: org.eclipse.update.feature,org.eclipse.m2e.logback.feature,1.6.2.20150902-0002
No repository found containing: osgi.bundle,org.eclipse.m2e.maven.indexer,1.6.2.20150902-0001
No repository found containing: osgi.bundle,org.eclipse.m2e.maven.runtime,1.6.2.20150902-0001
No repository found containing: osgi.bundle,org.eclipse.m2e.maven.runtime.slf4j.simple,1.6.2.20150902-0001
No repository found containing: osgi.bundle,org.eclipse.m2e.workspace.cli,0.3.1
No repository found containing: org.eclipse.update.feature,org.eclipse.m2e.wtp.feature,1.2.1.20150819-2220
No repository found containing: org.eclipse.update.feature,org.eclipse.m2e.wtp.jaxrs.feature,1.2.1.20150819-2220
No repository found containing: org.eclipse.update.feature,org.eclipse.m2e.wtp.jpa.feature,1.2.1.20150819-2224
No repository found containing: org.eclipse.update.feature,org.eclipse.m2e.wtp.jsf.feature,1.2.1.20150819-2220
No repository found containing: org.eclipse.update.feature,org.eclipse.mylyn.github.feature,4.0.3.201509231615-r
No repository found containing: org.eclipse.update.feature,org.eclipse.php,3.6.0.201509151953
No repository found containing: org.eclipse.update.feature,org.eclipse.rap.tools.feature,3.0.1.20150908-1020
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.m2e.sources,3.0.0.I20150529-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.mylyn.sources,3.0.0.I20150529-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.nl1,3.0.0.I20150529-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.nl1.sources,3.0.0.I20150529-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.resource.ignore.rules.jdt.sources,3.0.0.I20150529-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.revision.graph.sources,3.0.0.I20150529-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.source,3.0.4.I20160131-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.sources,3.0.4.I20160131-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.common.fproj,3.7.0.v201505072140
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.common_core.feature,3.7.1.v201508262220
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.common_ui.feature,3.7.1.v201508262220
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.jsdt.feature,1.6.201.v201508262249
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.server_adapters.feature,3.2.402.v201505042029
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.server_core.feature,3.3.600.v201508271522
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.server_ui.feature,3.3.600.v201509022125
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.web_core.feature,3.7.1.v201508271605
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.web_ui.feature,3.7.1.v201509022125
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.ws_core.feature,3.7.0.v201505131719
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.ws_ui.feature,3.7.1.v201508271926
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.xml_core.feature,3.7.0.v201502261749
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.xml_ui.feature,3.7.1.v201508271605
No repository found containing: org.eclipse.update.feature,org.sonatype.m2e.mavenarchiver.feature,0.17.0.201502101659-signed-20150525172209
No repository found containing: org.eclipse.update.feature,tern-feature,1.1.0.201511082254
No repository found containing: org.eclipse.update.feature,tern-jsdt-feature,1.1.0.201511082254
No repository found containing: org.eclipse.update.feature,tern-linters-feature,1.1.0.201511082254
No repository found containing: org.eclipse.update.feature,tern-server-nodejs-feature,1.1.0.201511082254
No repository found containing: org.eclipse.update.feature,tern.eclipse.ide.server.nodejs.embed,1.1.0.201511082254
Current Time: Thu Aug 28 22:42:13 EDT 2025
Powered by FUDForum. Page generated in 0.06632 seconds
