Home » Modeling » EMF » [CDO] Changing datatypes between model versions
[CDO] Changing datatypes between model versions [message #1690829] |
Tue, 31 March 2015 10:08  |
I am trying to transform my data model from one version of a metamodel to another one. In this particular case version 1 uses EDate and version 2 uses a custom datatype, but same attribute name. Both metamodels have a different namespace uri.
http://example/model/1: EClass: Example, Attribute date = EDate
http://example/model/2: EClass: Example, Attribute date = Custom EDataType
I currently load the model, manipulate it and then attempt to re-insert the updated data model back into CDO. However I get an exception along the lines of;
org.h2.jdbc.JdbcSQLException: Cannot parse "TIMESTAMP" constant "2010/01"; SQL statement:
INSERT INTO MODEL_EXAMPLE(CDO_ID, CDO_VERSION, CDO_CREATED, CDO_REVISED, CDO_RESOURCE, CDO_CONTAINER, CDO_FEATURE, DATE0, VALUE0) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?) -- (?1, ?2, ?3, ?4, ?5, ?6, ?7, ?8, ?9) [22007-168]
It appears the despite the different namespace URI, CDO is reusing the original namespace datatypes? Is there a way to resolve this? I have enabled the "qualifiedNames" property in the datastore.
// Load resource from CDO
CDOResource cdoResource = transaction.getResource("...");
// Move data into XMI based data file
ResourceSet rs = new ResourceSetImpl();
Resource tmpResource = rs.createResource(tmpURI);
tmpResource.getContents().add(cdoResource.getContents().get(0));
tmpResource.save(null);
// Make sure old reference to datamodel is gone
cdoResource.getContents().clear();
// Externally modify the XMI file
// Load the update data model instance
Resource tmpResource = rs.getResource(tmpURI);
// Move datamodel back into CDO
cdoResource.getContents().add(tmpResource.getContents().get(0));
transaction.commit();
Simon
Re: [CDO] Changing datatypes between model versions [message #1690834 is a reply to message #1690829] |
Tue, 31 March 2015 10:22   |
Hi Simon,
It seems you accept the fact that your import does not preserve the identities of the old objects?
Then it seems to me that you're trying to use both versions of your package in the same repo, right? Different nsURIs
are one precondition for that, but different model names are required, too, because otherwise the "qualifiedNames"
property can't do its job correctly.
Cheers
/Eike
http://www.esc-net.de
Am 31.03.2015 um 16:08 schrieb Simon Goodall:
> uri.
> Simon
Re: [CDO] Changing datatypes between model versions [message #1690862 is a reply to message #1690847] |
Tue, 31 March 2015 12:02   |
On 31/03/2015 16:12, Eike Stepper wrote:
> Am 31.03.2015 um 16:56 schrieb Simon Goodall:
>> "It seems you accept the fact that your import does not preserve the
>> identities of the old objects?"
>> Do you mean the internal CDO identifier? Is there a way to preserve
>> this? I am assuming that tracking history across metamodel changes is
>> not feasible.
> Not whenyou use EMF to do the actual instance migration. You may want to
> search this forum for former replies to the question of "model
> evolution" support in CDO. You should find some recipies that make use
> of the CDOServerExporter and CDOServerImporter.
I'll take a look, but this works on the repository as a whole rather than parts of it?
>> I am interested to know what the wider implications of this are. I am
>> still trying to understand how we can use the wider CDO feature set.
>> "Then it seems to me that you're trying to use both versions of your
>> package in the same repo, right? Different nsURIs are one precondition
>> otherwise the "qualifiedNames" property can't do its job correctly."
>> We have our current meta-model version, and now for CDO, previous
>> meta-model versions registered as dynamic packages.
> One problem might be/become that dynamic packages don't handle custom
> data types very well.
Ah yes. Is this a problem for CDO - what will it try to do? I override the EFactory methods in my migration code for this.
>> Normally we load these up in a local package registry instance and
>> migrate our data models using the dynamic EObject api. Changing the
>> model name also changes the generated java package. Is it possible to
>> avoid this ? Can we define a custom mapping somewhere?
> There's a model annotation http://www.eclipse.org/CDO/DBStore (tablename
> -> xyz) for specific EClasses but I fear we offer nothing for the
> EPackage -> tableQualifier mapping so far. If you want to work on that
> you should have a look at these members:
> org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.getTableName(EClass,
> EStructuralFeature)
> org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.getFieldName(EStructuralFeature)
> org.eclipse.emf.cdo.server.internal.db.DBAnnotation
So here we could add something like TABLE_QUALIFIER to the DBAnnotation and then add the annotation to the EPackage declaration in my ecore file? In
getTableName() add it as a postfix to the generated name? E.g.;
public String getTableName(EClass eClass, EStructuralFeature feature)
String name = DBAnnotation.TABLE_NAME.getValue(eClass);
if (name == null)
name = isQualifiedNames() ? EMFUtil.getQualifiedName(eClass, NAME_SEPARATOR) : eClass.getName();
String qualifier = DBAnnotation.TABLE_QUALIFIER.getValue(eClass.getEPackage());
if (qualifier != null)
name += NAME_SEPARATOR;
name += qualifier;
How does AbstractMappingStrategy.getFieldName fit into this?
Simon
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: [CDO] Changing datatypes between model versions [message #1690931 is a reply to message #1690862] |
Wed, 01 April 2015 01:04   |
Am 31.03.2015 um 18:02 schrieb Simon Goodall:
>>> not feasible.
Yes.
> this.
Ok.
>> EStructuralFeature)
> declaration in my ecore file? In getTableName() add it as a postfix to the generated name? E.g.;
> if (name == null)
I would probably replace the call to EMFUtil.getQualifiedName() here and in the other getTableName() method.
> name += qualifier;
I think that field names are kind of orthogonal here.
Cheers
/Eike
> Simon
>> Cheers
>> /Eike
Re: [CDO] Changing datatypes between model versions [message #1691010 is a reply to message #1690931] |
Wed, 01 April 2015 10:42   |
It is possible to re-import and manipulate the CDOObject fields to match the ID? (I assume this is not a good idea if it is possible...)
>>>> not feasible.
> Yes.
I can image the size of the XML files can get quite large. Does anyone have experience processing large data dumps this way? I see BaseX is mentioned in
previous posts as a way to transform the XML. Is this still recommended?
I tried running the XML export on my repository and it threw an exception when it hit some serialised objects. It does not seem to handle byte arrays. Due to
some (badly defined) generics in my data model my EIntObject and EDoubleObject objects hit the object serialisation code in the default EFactory code.
> Ok.
>>> EStructuralFeature)
>> if (name == null)
>> name += qualifier;
OK. I'll try this way for now, but looks like the CDOServerExporter is the better way longer term.
Simon
> Cheers
> /Eike
>> Simon
>>> Cheers
>>> /Eike
Current Time: Fri Jul 25 22:53:15 EDT 2025
Powered by FUDForum. Page generated in 0.06544 seconds
