Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] DAO configuration and JSON customization(DAO configuration and JSON customization)
[Texo] DAO configuration and JSON customization [message #1653719] Fri, 06 March 2015 05:56 Go to next message
2 questions.
1. How does the EntityManagerProvider know which database to use. Could not find the reference to configuring the underlying database, h2 in my case. I generated DAO classes, maybe should have done JPA as I know about persistence.xml. Not clear how I would attach my dao context.xml file to the EntityManagerProvider. Once the system is initialised and H2 creates an empty database, will the EntityManager automatically create the required schema?
2. The team I am working with have already written the JSON calls in the js client, of course the structure of the JSON does not match the automatically generated JSON structures Texo produces. Wondering if you can alter the JSON structure. Not really a problem as I will just use a separate Jersey supported JSON service and be satisfied with the DAO support Texo provides.
David
[Updated on: Fri, 06 March 2015 06:00] by Moderator
Re: [Texo] DAO configuration and JSON customization [message #1653793 is a reply to message #1653719] Fri, 06 March 2015 06:38 Go to previous messageGo to next message
Hi David,
See replies inline.
gr. Martin
On 06-03-15 11:56, David Wynter wrote:
> 2 questions.
MT>> There should be a persistence.xml which does this. The DAO classes uses JPA/EntityManager calls to persist data.
> Not really problem as I will just use a separate Jersey supported JSON service and be satisfied with the DAO support
> Texo provides.
MT>> Texo has a simple/effective component concept:
https://wiki.eclipse.org/Texo/Components
In this case you can extend the JSONServiceContext (which is also a component) with your own subclass, override the
setRequestContent method for example to convert your json-string to something Texo expects.
There are also several points/components you can replace to convert what Texo expects.
One thing what Texo does with JSON is that it resolves object references to data from the database or new objects (if
needed). That's something you can make use of maybe.
btw, if you don't use the Texo JSONRestWebServiceServlet you can also directly use the Texo model operations with your
custom service context. There are these modeloperations:
RetrieveModelOperation
UpdateInsertModelOperation
DeleteModelOperation
The flow is something like this:
final UpdateInsertModelOperation operation = ComponentProvider.getInstance().newInstance(
UpdateInsertModelOperation.class);
operation.setServiceContext(serviceContext);
operation.execute();
then after this call the serviceContext.getResponseContext() will contain the resulting json.
In any case, if your json format is something standard then you can also let me know if it makes sense to support it in
Texo itself.
gr. Martin
> Regards,
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] DAO configuration and JSON customization [message #1690686 is a reply to message #1653793] Mon, 30 March 2015 11:37 Go to previous messageGo to next message
Just the connection to DAO is my outstanding issue
I am trying to test some of my DAO code using JUnit. In the setup() method I have this
        final PssErrorTypeDao errTypeDao = DaoRegistry.getInstance().getDao(PssErrorTypeDao.class);
It returns null.
I had moved a copy of my META-INF/persistance.xml to the src/main directory as it is on the classpath.
In it I have
	<persistence-unit name="pss_h2" transaction-type="RESOURCE_LOCAL">
		<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
		<class>org.example.pss.PssErrorType</class>
		<properties>
            <property name="eclipselink.target-database" value="org.eclipse.persistence.platform.database.H2Platform"/>
            <property name="javax.persistence.jdbc.driver" value="org.h2.Driver"/>
            <property name="javax.persistence.jdbc.url" value="jdbc:h2:file://~/git/pss/db;DB_CLOSE_ON_EXIT=FALSE;AUTO_SERVER=TRUE"/>
         	<property name="javax.persistence.jdbc.user" value="sa"/>
            <property name="javax.persistence.jdbc.password" value="@@@"/>
			<!-- EclipseLink should create the database schema automatically -->
			<property name="eclipselink.ddl-generation" value="drop-and-create-tables" />
			<property name="eclipselink.ddl-generation.output-mode" value="database" />
		</properties>
	</persistence-unit>
</persistence>
Is there anything else I need for the DaoRegistry to be properly initialised?
[Updated on: Mon, 30 March 2015 11:40] by Moderator
Re: [Texo] DAO configuration and JSON customization [message #1690731 is a reply to message #1690686] Mon, 30 March 2015 17:31 Go to previous messageGo to next message
Hi David,
In the generated ModelPackage initialize method there should be a line like this:
DaoRegistry.getInstance().registerDao(ActionType.class, ActionTypeDao.class);
If it is there then I guess you need to touch the model package before you try the code before, for example by calling
initialize on the model package.
Let me know if it works then I will change the wiki.
gr. Martin
On 30-03-15 17:37, David Wynter wrote:
> It returns null.
> In it I have
> <class>com.rmg.parcels.pss.PssErrorType</class>
> <properties>
> </properties>
> </persistence-unit>
> </persistence>
The Netherlands
Re: [Texo] DAO configuration and JSON customization [message #1690861 is a reply to message #1690731] Tue, 31 March 2015 12:02 Go to previous messageGo to next message
Martin,
The initialize method worked. But not sure how Texo resolves the persistence.xml file? The JUnit test I run from Eclipse, where I ended up explicitly adding to the resource classpath runtime of the JUnit runner the directory where the copy of the persistence.xml is and still it fails to load it, see the code below, it prints out null
	public void setUp() throws Exception {
		// Insert the errortypes
        String err = PssErrorTypes.getErrorTypes();
        ParcelSystemSimulationModelPackage.initialize();
        System.out.println(getClass().getResource("META-INF/persistence.xml"));
The file is under src/test/resources/META-INF/persistence.xml Both src/test and explicitly src/test/resource are on the class path according to the eclipse debug configuration for this Junit test. I realise probably a Eclipse issue. Will setup a test section in the pom.xml next to see if I can get it to run from there.
thx
David
[Updated on: Tue, 31 March 2015 12:03] by Moderator
Re: [Texo] DAO configuration and JSON customization [message #1690915 is a reply to message #1690861] Tue, 31 March 2015 17:25 Go to previous messageGo to next message
Hi David,
The ORM does the resolving/finding of the persistence.xml, in my case I have META-INF directly within src. Maybe it goes
wrong with you because src/test/resources is a subdirectory src/test which is also on the classpath.So maybe moving
META-INF one level up solves it.
gr. Martin
On 31-03-15 18:02, David Wynter wrote:
> Martin,
> The initialize method worked. But not sure how Texo resolves the persitance.xml file? My JUnit test I run from Eclipse,
> where I ended up explicitly adding to the resurce classpath runtime of the JUnit runner the directory where the copy of
> thx
> David
The Netherlands
Re: [Texo] DAO configuration and JSON customization [message #1691090 is a reply to message #1690915] Thu, 02 April 2015 05:35 Go to previous messageGo to next message
It turned out to be some Windows thing, it changed my file permissions to admin for the target class path, so it could not output the new version of the classes?! Anyway sorted that out. Followed your advice an moved the META-INf/persistance to my src-gen top package. Now it does print out the resource in console, see code above. But despite persistence.xml now being on the classpath I still get
javax.persistence.PersistenceException: No Persistence provider for EntityManager named pss_h2
	at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:85)
	at com.example.parcels.pss.resources.ReferenceResourceTests.setUp(ReferenceResourceTests.java:49)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
	at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
	at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
	at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:27)
	at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31)
	at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:69)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:48)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:292)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
So tried this
        Map<String, String> properties = new HashMap<String, String>();
        properties.put("eclipselink.target-database", "org.eclipse.persistence.platform.database.H2Platform");
        properties.put("javax.persistence.jdbc.driver", "org.h2.Driver");
        properties.put("eclipselink.ddl-generation", "drop-and-create-tables");
        properties.put("eclipselink.ddl-generation.output-mode", "database");
        properties.put("javax.persistence.jdbc.user", "sa");
        properties.put("javax.persistence.jdbc.url", "jdbc:h2:file://C:/Users/myuser/git/pss/db/pss_db;DB_CLOSE_ON_EXIT=FALSE;AUTO_SERVER=TRUE");
        properties.put("javax.persistence.jdbc.password", "pss@1234");
        EntityManagerFactory emf = Persistence.createEntityManagerFactory(
            "pss_h2", properties);
Same result. How do I get deeper trace detail to find out why it does not use the valid persistence.xml to create the required EntityManagerFactory instance?
[Updated on: Thu, 02 April 2015 06:00] by Moderator
Re: [Texo] DAO configuration and JSON customization [message #1691091 is a reply to message #1690915] Thu, 02 April 2015 05:38 Go to previous messageGo to next message
It turned out to be some Windows thing, it changed my file permissions to admin for the target class path?! Anyway sorted that out. Followed your advice an moved the META-INF/persistance to my src-gen top package.
I use the std EntityManagerFactory code prior to the DaoRegistry code to prove the persistence.xml is being picked up. Although it appears not completely?
        EntityManagerFactory emf = Persistence.createEntityManagerFactory("pssh2");
        EntityManager em = emf.createEntityManager();
persistence.xml
<persistence version="2.0"
	xmlns="http://java.sun.com/xml/ns/persistence"
	xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd">
	<persistence-unit name="pssh2" transaction-type="RESOURCE_LOCAL">
		<class>com.example.parcels.pss.AdvancedConfig</class>
		<class>com.example.parcels.pss.AdvancedConfigPreAdviceQuality</class>
		<class>com.example.parcels.pss.BasicConfig</class>
		<class>com.example.parcels.pss.ChannelMeta</class>
		<class>com.example.parcels.pss.CustomerMeta</class>
		<class>com.example.parcels.pss.ErrorType</class>
		<class>com.example.parcels.pss.PssErrorType</class>
		<class>com.example.parcels.pss.MetaConfig</class>
		<class>com.example.parcels.pss.MPEMeta</class>
		<class>com.example.parcels.pss.SenderMeta</class>
		<class>com.example.parcels.pss.TrailerMeta</class>
		<class>com.example.parcels.pss.PreAdviceHdrMeta</class>
		<class>com.example.parcels.pss.Rule</class>
		<class>com.example.parcels.pss.ScheduleRun</class>
		<properties>
            <property name="javax.persistence.jdbc.url" value="jdbc:h2:file://C:/Users/david.user/git/pss/db/pss_db;DB_CLOSE_ON_EXIT=FALSE;AUTO_SERVER=TRUE"/>
            <property name="javax.persistence.jdbc.password" value="******"/>
			<property name="eclipselink.ddl-generation.output-mode" value="both" />
		</properties>
	</persistence-unit>
</persistence>
This is the output from the EntityManager, it does not show the 12 <class></class> entries I have in my persistence.xml
[EL Info]: 2015-04-02 11:37:07.785--ServerSession(1754570454)--EclipseLink, version: Eclipse Persistence Services - 2.3.0.v20110604-r9504
[EL Info]: 2015-04-02 11:37:12.714--ServerSession(1754570454)--file:/C:/Users/david.wynter/git/pss/target/classes/_pssh2 login successful
[EL Warning]: 2015-04-02 11:37:12.78--The collection of metamodel types is empty. Model classes may not have been found during entity search for Java SE and some Java EE container managed persistence units.  Please verify that your entity classes are referenced in persistence.xml using either <class> elements or a global <exclude-unlisted-classes>false</exclude-unlisted-classes> element
Finally I get this trace form the DaoRegistry call
javax.persistence.PersistenceException: No Persistence provider for EntityManager named null
	at org.eclipse.emf.texo.server.store.EntityManagerProvider.initialize(EntityManagerProvider.java:73)
	at org.eclipse.emf.texo.server.store.EntityManagerProvider.createEntityManager(EntityManagerProvider.java:86)
	at org.eclipse.emf.texo.server.store.EntityManagerProvider.getEntityManager(EntityManagerProvider.java:99)
	at org.eclipse.emf.texo.server.store.BaseDao.getEntityManager(BaseDao.java:77)
any ideas?
[Updated on: Thu, 02 April 2015 06:53] by Moderator
Re: [Texo] DAO configuration and JSON customization [message #1691099 is a reply to message #1691091] Thu, 02 April 2015 06:18 Go to previous messageGo to next message
Hi David,
Can also be caused by that eclipselink is not found, can you check that indeed the eclipselink jar is on the classpath?
And for completeness can you post the persistence.xml? This is running junit? (or junit plugin test)
gr. Martin
On 02-04-15 11:38, David Wynter wrote:
> out the resource in console, using
> at com.rmg.parcels.pss.resources.ReferenceResourceTests.setUp(ReferenceResourceTests.java:49)
> So tried this
> Same result. How do I get deeper trace detail to find out why it doe snot use the valid persistence.xml to create the
The Netherlands
Re: [Texo] DAO configuration and JSON customization [message #1691107 is a reply to message #1691099] Thu, 02 April 2015 07:05 Go to previous messageGo to next message
I checked the Eclipse Debug Configuration for the JUnit test I am running. It shows that my project is included, and it include all the jars you specified, including eclipselink.jar and the required h2 jar in WebContent/WEB-INF/lib. It also includes the javax.persistence jar, which is being picked up by the code I edited in the earlier post I did above. I.e. std EntityManagerFactory appears to find that jar which is in the same directory. Also, wouldn't something throw an exception is eclipselink.jar was not on the classpath?
Thx.
David
[Updated on: Thu, 02 April 2015 07:30] by Moderator
Re: [Texo] DAO configuration and JSON customization [message #1691113 is a reply to message #1691107] Thu, 02 April 2015 07:38 Go to previous messageGo to next message
Hi David,
The exception you mention can happen when there is no ORM on the classpath and no I don't think you would get an earlier
exception as you can do ORM things before getting the entitymanagerfactory.
can you send me the persistence.xml? Just to see what's in there.
gr. Martin
On 02-04-15 13:05, David Wynter wrote:
> includes the javax.persitence jar, which is being picked up by the code I edited in the earlier post I did above. I.e.
> exception is eclipselink.jar wa snot on the classpath?
> Thx.
> David
The Netherlands
Re: [Texo] DAO configuration and JSON customization [message #1691114 is a reply to message #1691107] Thu, 02 April 2015 08:00 Go to previous messageGo to next message
OK, this is interesting, clearly a problem with my persistence.xml.
I included this
And it gave me this error
Exception Description: Predeployment of PersistenceUnit [pssh2] failed.
Internal Exception: Exception [EclipseLink-7161] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.ValidationException
Exception Description: Entity class [class com.example.parcels.pss.actors.CreatePreAdvice] has no primary key specified. It should define either an @Id, @EmbeddedId or an @IdClass. If you have defined PK using any of these annotations then make sure that you do not have mixed access-type (both fields and properties annotated) in your entity class hierarchy.
Which is expected, because I don't want all of my generated classes to be persisted, which is why I explicitly use the <class></class> properties.
So the question is that my perisistence.xml is wrong in some way, but the code does not throw an exception due to that particular error, because it does for other errors as shown above.
Re: [Texo] DAO configuration and JSON customization [message #1691154 is a reply to message #1691114] Thu, 02 April 2015 11:11 Go to previous messageGo to next message
Trying to understand the relationship between the EntityManagerProvider and DaoRegistry.
You can see here I explicitly set the EntityManager in the EntityManagerProvider.
But when the DaoRegistry instance returns the PssErrorTypeDao the field that holds the EntityManager is null? So they appear unconnected.
Not sure what other steps are required to make sure the Dao objects returned are initialised. I note that the entityName field is null too?
        EntityManagerProvider.getInstance().setEntityManagerFactory(emf);
        EntityManagerProvider.getInstance().setCurrentEntityManager(em);
It appears despite having these 2 fields null it works, but is still not recognising all the <class> entries in the persistence.xml, because I get this:
[code]
java.lang.IllegalArgumentException: Object: PssErrorType [code: GAN] [description: Check the value in 'Header' field: 'Generic Account Number' is valid (Applicable for DOSS, DMO and Shipping API channels)] [fieldApplied: Generic Account Number] is not a known entity type.
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerNewObjectForPersist(UnitOfWorkImpl.java:4158)
[/code]
Maybe I have misread, is a annotations model mandatory? It does not seem so from this page: - http://wiki.eclipse.org/Texo/Code_Generation_Details
[Updated on: Thu, 02 April 2015 11:44] by Moderator
Re: [Texo] DAO configuration and JSON customization [message #1691157 is a reply to message #1691154] Thu, 02 April 2015 11:50 Go to previous messageGo to next message
Hi David,
Also call the setUseCurrentEntityManagerPattern on the entity manager provider... This feature is used in Texo testing
so therefore misses this last fine print doc that you need to call this method. I will add it to the javadoc at least.
The entityName in the DAO is computed when you call getEntityName not before (as it needs the entitymanager).
The EntityManagerFactory gets created correctly? If not can you post the persistence.xml?
gr. Martin
> appear unconnected.
> field is null too?
The Netherlands
Re: [Texo] DAO configuration and JSON customization [message #1691428 is a reply to message #1691157] Tue, 07 April 2015 04:40 Go to previous messageGo to next message
I added the call but still get the exception. The persistence.xml is the one you see in an earlier message, message #1691091. I inspect the field values in the debugger for both EntityManagerFactory and EntityManager and can see the list of classes defined in the persistence.xml, under em/factory/setupImpl/persistenceUnitInfo/managedClassNames/elementData. I also checked it's structure against the Oracle reference for persistence.xml and it looks ok, maybe I am missing something?
        EntityManagerProvider.getInstance().setUseCurrentEntityManagerPattern(true);
Exception
[code]
java.lang.IllegalArgumentException: Object: PssErrorType [code: GAN] [description: Check the value in 'Header' field: 'Generic Account Number' is valid (Applicable for COSS, DMO and Shipping API channels)] [fieldApplied: Generic Account Number] is not a known entity type.
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.persist(EntityManagerImpl.java:440)
at org.eclipse.emf.texo.server.store.BaseDao.insert(BaseDao.java:204)
at com.example.parcels.pss.resources.ReferenceResourceTests.setUp(ReferenceResourceTests.java:57)
[/code]
I'll continue to try to alter persistence.xml to see if I can get the em of emf to pick up the classes defined. If not then create a separate mapping file .
[Updated on: Tue, 07 April 2015 05:46] by Moderator
Re: [Texo] DAO configuration and JSON customization [message #1691471 is a reply to message #1691428] Tue, 07 April 2015 09:27 Go to previous messageGo to next message
I tried to use the EntityManager.persist method and it fails with the same exception. So something about the EntityManager is not formed correctly. While it has the persistent classes defined in it's structure something else internally causes it to fail. Could this be due to me running this from a JUnit test? I do add the entire project to the classpath so the classes should be visible to EntityManager, the fact it reads the persistence.xml which is in the same directory structure suggests it can read that path.
I note that the console log shows this :
[EL Warning]: 2015-04-07 14:25:16.286--The collection of metamodel types is empty. Model classes may not have been found during entity search for Java SE and some Java EE container managed persistence units. Please verify that your entity classes are referenced in persistence.xml using either <class> elements or a global <exclude-unlisted-classes>false</exclude-unlisted-classes> element
So even though the classes are listed in the EntityManager instance structure it appears it cannot find them? I am assuming that in addition to the place I found them listed they should also be listed here too for it to work:
MetamodelImpl@1710971789 [ 0 Types: , 0 ManagedTypes: , 0 EntityTypes: , 0 MappedSuperclassTypes: , 0 EmbeddableTypes: ]
[Updated on: Tue, 07 April 2015 09:34] by Moderator
Re: [Texo] DAO configuration and JSON customization [message #1691489 is a reply to message #1691471] Tue, 07 April 2015 11:11 Go to previous messageGo to next message
I got it to work by making sure I generated JPA with DAO and then going through and all classes in the ecore that have a field where ID == true I changed the generated code from using a @Basic() annotation on that field to a @Id() annotation.
[Updated on: Tue, 07 April 2015 11:48] by Moderator
Re: [Texo] DAO configuration and JSON customization [message #1691520 is a reply to message #1691489] Tue, 07 April 2015 15:06 Go to previous messageGo to next message
Hi David,
Hmm, these annotations should be generated automatically when you choose generate JPA annotated model code. Did you do
that (I assumed this..) or choose another generation method?
gr. Martin
On 07-04-15 17:11, David Wynter wrote:
> Got std JPA ith DAO to work by adding the @Entity and @Id annotations to the domain classes generated by Texo. Will have
> to forego extra Texo features, at least I can persist now.
The Netherlands
Re: [Texo] DAO configuration and JSON customization [message #1691620 is a reply to message #1691520] Wed, 08 April 2015 09:58 Go to previous message
I must have l clicked on the "Generate Model + Dao code" menu at some point. When I realised this I then clicked the "Generate JPA Annotated Model + Dao" menu it generated the annotations.
The only issue I had was even though all my persisted classes have a field with Unique=true and ID=true the annotation generated for these was @Basic and not @Id, so I changed them manually and where appropriate (EInt) added @GeneratedValue with args.
Thx.
David
Previous Topic:[EEF] Update to tutorial
Next Topic:[Teneo] How can I persist java.util.Calendar as "timestamp with timezone"?
Current Time: Wed Jul 23 21:36:27 EDT 2025
Powered by FUDForum. Page generated in 0.26502 seconds
