Home » Language IDEs » AspectJ » Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compilati(Problem installing ajdt on Eclipse)
Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compilati [message #1077524] Thu, 01 August 2013 16:56 Go to next message
After I install the AJDT 2.2.3 on Rational Software Archtect, every Editor displays the error: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor
I am using the Rational Software Architect 9 with Eclipse 4.2.2. Used the link (http://download.eclipse.org/tools/ajdt/42/update) to install the AJDT.
Searching on the web I found this:http://www.eclipse.org/forums/index.php/t/74968/), but removing the Data Tools did not work for me.
I also updated the Data Tools to 1.10.2, and yet not working.
Can anybody help me? Here is the details stack :
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:62)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:112)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:262)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:299)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:88)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55)
at java.lang.reflect.Method.invoke(Method.java:613)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:861)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:841)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:113)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:321)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:242)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:894)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:629)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:520)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:505)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:74)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:731)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:702)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:696)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:681)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1128)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:641)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:647)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:987)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jdt.ui (1544).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:690)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
... 104 more
Caused by: org.osgi.framework.BundleException: The activator org.eclipse.jdt.internal.ui.JavaPlugin for bundle org.eclipse.jdt.ui is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:172)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
... 116 more
Caused by: org.aspectj.apache.bcel.classfile.ClassFormatException: org.eclipse.jdt.core.WorkingCopyOwner is not a Java .class file
at org.aspectj.apache.bcel.classfile.ClassParser.readID(ClassParser.java:215)
at org.aspectj.apache.bcel.classfile.ClassParser.parse(ClassParser.java:124)
at org.aspectj.weaver.bcel.Utility.makeJavaClass(Utility.java:467)
at org.aspectj.weaver.bcel.BcelWorld.addSourceObjectType(BcelWorld.java:499)
at org.aspectj.weaver.tools.WeavingAdaptor.ensureDelegateInitialized(WeavingAdaptor.java:513)
at org.aspectj.weaver.tools.WeavingAdaptor$WeavingClassFileProvider.<init>(WeavingAdaptor.java:843)
at org.aspectj.weaver.tools.WeavingAdaptor.getWovenBytes(WeavingAdaptor.java:526)
at org.aspectj.weaver.tools.WeavingAdaptor.weaveClass(WeavingAdaptor.java:363)
at org.eclipse.equinox.weaving.aspectj.loadtime.OSGiWeavingAdaptor.weaveClass(Unknown Source)
at org.eclipse.equinox.weaving.aspectj.AspectJWeavingService.preProcess(Unknown Source)
at org.eclipse.equinox.weaving.adaptors.WeavingAdaptor.weaveClass(Unknown Source)
at org.eclipse.equinox.weaving.hooks.WeavingHook.processClass(Unknown Source)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:600)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:568)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:492)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:465)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at java.lang.J9VMInternals.verifyImpl(Native Method)
at java.lang.J9VMInternals.verify(J9VMInternals.java:93)
at java.lang.J9VMInternals.initialize(J9VMInternals.java:170)
at java.lang.J9VMInternals.newInstanceImpl(Native Method)
at java.lang.Class.newInstance(Class.java:1600)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:167)
... 122 more
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1078379 is a reply to message #1077524] Fri, 02 August 2013 19:49 Go to previous messageGo to next message
I have not seen this error before. Please try disabling JDT weaving (in Preferences -> JDT weaving, must restart).
Also, which JRE version are you using?
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1079003 is a reply to message #1078379] Sat, 03 August 2013 19:26 Go to previous messageGo to next message
The JDT weaving is already disabled, and I can't enable it. I press the button, the Eclipse restarts, but it remains disabled.
Another point: I was searching for the installed JRE in preferences, but when I click Preferences -> Java I got an error: "An error has occurred when creating this preference page." And when I try the "Installed JRE's I got a popup: "Unable to create the selected preference page. An error occurred while automatically activating bundle org.eclipse.jdt.debug.ui(1537)"
Another thing I am not sure if it is clear. The Editors I was mentioning were the Java File Editor, The Package Explorer, the Java View. I tryed to open an .xml file and it seems to work fine.
Thanks for your attention.
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1079009 is a reply to message #1079003] Sat, 03 August 2013 19:39 Go to previous messageGo to next message
Here is a picture of the eclipse error tab (perhaps it may help):
index.php/fa/15823/0/
  • Attachment: ajdt.PNG
    (Size: 87.95KB, Downloaded 79675 times)
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1079155 is a reply to message #1079009] Sun, 04 August 2013 01:12 Go to previous messageGo to next message
There is definitely something odd going on. When it is not possible to enable jdt weaving, that typically means something is wrong with Eclipse's configuration. Can you attach you .log file here? Not a screenshot, but the entire log file. Best to do this:
1. clear the log (press red X)
2. restart and open the preference page that produces the error.
3. export the log file
4. attach it here
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1079343 is a reply to message #1079155] Sun, 04 August 2013 08:20 Go to previous messageGo to next message
Here it is...
  • Attachment: ajdt.log
    (Size: 389.96KB, Downloaded 1434 times)
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1080400 is a reply to message #1079343] Mon, 05 August 2013 18:39 Go to previous messageGo to next message
Thanks for the error log. I see a few problems. First, it looks like you are using the J9 JVM. Equinox weaving and aspectj *should* work on J9, but we don't actually have any tests for that, so something may have broken. Two suggestions:
1. use a Hotspot JVM instead
2. force-disable equonox weaving:
a. open eclipse/configuration/org.eclipse.equinox.simpleconfigurator/bundles.info (after first making a backup)
b. look for the lines for the bundles org.eclipse.equinox.weaving.* and delete them.
c. restart eclipse and equinox weaving should be disabled permanently.
You will see an error at startup, but you can ignore that. Also, most of the advanced editing functionality of AJDT will be disabled.
Regardless, I'd recommend that you raise a bug report with AspectJ since there may be a problem with the compiler. Do so here: https://bugs.eclipse.org/
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1080850 is a reply to message #1080400] Tue, 06 August 2013 08:57 Go to previous messageGo to next message
Hi Andrew
Thanks for your help.
I can't use the Hotspot JVM at work (only the J9 JVM), so I tryed the second option and it seems to work (I was able to open the editors). I haven't yet tryed to compile my project using aspects, since I am still configuring my environment but once I do that I will post here.
I also raised the bug repord: https://bugs.eclipse.org/bugs/show_bug.cgi?id=414487
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1080969 is a reply to message #1080850] Tue, 06 August 2013 12:20 Go to previous messageGo to next message
Thanks for raising the bug report. Compilation should not be affected, but editing will. You may be getting misleading error markers in your editors and you will not be able to see the affects of intertype declarations. Also, you will not be able to see aspects in the "Open type declaration" dialog or in search results.
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1087257 is a reply to message #1080969] Thu, 15 August 2013 07:24 Go to previous messageGo to next message
Thanks for sharing this report
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1135893 is a reply to message #1077524] Sun, 13 October 2013 09:45 Go to previous messageGo to next message
It is my first time to use this site, I hope I use it correctly
I have the same AJDT issue.
I am using RAD 8.0.4.2 and WAS 6.1.
After I installed AJDT ((http://download.eclipse.org/tools/ajdt/43/update), I was searching for the installed JRE in preferences, but when I click Preferences -> Java I got an error: "An error has occurred when creating this preference page." And when I try the "Installed JRE's I got a popup: "Unable to create the selected preference page. An error occurred while automatically activating bundle org.eclipse.jdt.debug.ui(1448)"
I also tried force-disable equonox weaving, but it is not working.
Here is my error log. Please help!!!!!!
!ENTRY org.eclipse.equinox.registry 4 1 2013-10-13 09:09:14.819
!MESSAGE Unable to create the selected preference page.
!STACK 0
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jdt.debug.ui (1488).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(Unknown Source)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(Unknown Source)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(Unknown Source)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(Unknown Source)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(Unknown Source)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Unknown Source)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(Unknown Source)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(Unknown Source)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(Unknown Source)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(Unknown Source)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(Unknown Source)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(Unknown Source)
at org.eclipse.swt.custom.BusyIndicator.showWhile(Unknown Source)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Unknown Source)
at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceNode.createPage(Unknown Source)
at org.eclipse.jface.preference.PreferenceDialog.createPage(Unknown Source)
at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.createPage(Unknown Source)
at org.eclipse.jface.preference.PreferenceDialog.showPage(Unknown Source)
at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.showPage(Unknown Source)
at org.eclipse.jface.preference.PreferenceDialog$10.run(Unknown Source)
at org.eclipse.jface.preference.PreferenceDialog$9.selectionChanged(Unknown Source)
at org.eclipse.jface.viewers.StructuredViewer$3.run(Unknown Source)
at org.eclipse.core.runtime.SafeRunner.run(Unknown Source)
at org.eclipse.ui.internal.JFaceUtil$1.run(Unknown Source)
at org.eclipse.jface.util.SafeRunnable.run(Unknown Source)
at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(Unknown Source)
at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect(Unknown Source)
at org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected(Unknown Source)
at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(Unknown Source)
at org.eclipse.jface.util.OpenStrategy.access$5(Unknown Source)
at org.eclipse.jface.util.OpenStrategy$3.run(Unknown Source)
at org.eclipse.swt.widgets.RunnableLock.run(Unknown Source)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Unknown Source)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch(Unknown Source)
at org.eclipse.jface.window.Window.runEventLoop(Unknown Source)
at org.eclipse.jface.window.Window.open(Unknown Source)
at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.open(Unknown Source)
at org.eclipse.ui.internal.OpenPreferencesAction.run(Unknown Source)
at org.eclipse.jface.action.Action.runWithEvent(Unknown Source)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(Unknown Source)
at org.eclipse.jface.action.ActionContributionItem.access$2(Unknown Source)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Widget.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Unknown Source)
at org.eclipse.ui.internal.Workbench.runEventLoop(Unknown Source)
at org.eclipse.ui.internal.Workbench.runUI(Unknown Source)
at org.eclipse.ui.internal.Workbench.access$4(Unknown Source)
at org.eclipse.ui.internal.Workbench$7.run(Unknown Source)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Unknown Source)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Unknown Source)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(Unknown Source)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Unknown Source)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Unknown Source)
at org.eclipse.equinox.launcher.Main.basicRun(Unknown Source)
at org.eclipse.equinox.launcher.Main.run(Unknown Source)
at org.eclipse.equinox.launcher.Main.main(Unknown Source)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.jdt.internal.debug.ui.JDIDebugUIPlugin.start() of bundle org.eclipse.jdt.debug.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(Unknown Source)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(Unknown Source)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(Unknown Source)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(Unknown Source)
at org.eclipse.osgi.framework.util.SecureAction.start(Unknown Source)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(Unknown Source)
... 74 more
Caused by: java.lang.NoClassDefFoundError: org.eclipse.jdt.debug.core.IJavaVariable
at org.eclipse.jdt.internal.debug.ui.JDIDebugUIPlugin.start(Unknown Source)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Unknown Source)
... 80 more
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1137620 is a reply to message #1135893] Mon, 14 October 2013 12:16 Go to previous messageGo to next message
It looks like something got messed up on install. Can you try uninstalling and reinstalling? Also, answer the following questions:
1. Do you have write access to the Eclipse install location?
2. Do you have the ScalaIDE installed or any other language development tools?
You can also force disabling of JDT weaving by going to Eclipse/configuration/org.eclipse.equinox.simpleconfigurator/bundles.info and look for the line org.eclipse.equinox.weaving.aspectj. Change 'true' to 'false'. This will prevent Equinox weaving for AspectJ from being auto-started.
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1272915 is a reply to message #1077524] Wed, 19 March 2014 00:03 Go to previous messageGo to next message
It just only need to restart your eclipse. I trying many way to resolve this error. I did install both eclipse and STS. Try it to restart. just only to restart.
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1690794 is a reply to message #1272915] Tue, 31 March 2015 06:22 Go to previous messageGo to next message
Another point: I was searching for the installed JRE in preferences, but when I click Preferences -> Java I got an error: "An error has occurred when creating this preference page " And when I try the "Installed JRE's I got a popup: "Unable to create the selected preference page. An error occurred while automatically activating bundle org.eclipse.jdt.debug.ui(1537)".
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1690856 is a reply to message #1690794] Tue, 31 March 2015 11:39 Go to previous messageGo to next message
Open up your error log and paste any relevant errors here.
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1732841 is a reply to message #1077524] Fri, 20 May 2016 12:25 Go to previous messageGo to next message
I have installed STS plugin today in my Eclipse Mars .2 and when it restarts i am having errors below in the package explorer.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:178)
at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:58)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:101)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:279)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:317)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:898)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:879)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:121)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:345)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:264)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:971)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:640)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:525)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:509)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:69)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:746)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:717)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:711)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:695)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeTopicToBeRendered(PartRenderingEngine.java:142)
at sun.reflect.GeneratedMethodAccessor134.invoke(Unknown Source)
at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:83)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:85)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setToBeRendered(UIElementImpl.java:303)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:567)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:536)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:724)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:701)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:639)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:634)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1157)
at org.eclipse.ui.internal.WorkbenchPage.showPart(WorkbenchPage.java:1276)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1267)
at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.java:4238)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:4234)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:4214)
at org.eclipse.ui.handlers.ShowViewHandler.openView(ShowViewHandler.java:127)
at org.eclipse.ui.handlers.ShowViewHandler.execute(ShowViewHandler.java:87)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:343)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:830)
at org.eclipse.ui.menus.CommandContributionItem.access$21(CommandContributionItem.java:816)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:806)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4230)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1491)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1514)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1499)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1299)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4072)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3698)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
Caused by: java.lang.LinkageError: loader constraint violation: when resolving field "generatedClassHandler" the class loader (instance of org/eclipse/osgi/internal/loader/EquinoxClassLoader) of the referring class, org/aspectj/weaver/tools/WeavingAdaptor, and the class loader (instance of org/eclipse/osgi/internal/loader/EquinoxClassLoader) for the field's resolved type, org/aspectj/weaver/tools/GeneratedClassHandler, have different Class objects for that type
at org.eclipse.equinox.weaving.aspectj.loadtime.OSGiWeavingAdaptor.initialize(OSGiWeavingAdaptor.java:235)
at org.eclipse.equinox.weaving.aspectj.AspectJWeavingService.ensureAdaptorInit(AspectJWeavingService.java:83)
at org.eclipse.equinox.weaving.aspectj.AspectJWeavingService.preProcess(AspectJWeavingService.java:151)
at org.eclipse.equinox.weaving.adaptors.WeavingAdaptor.weaveClass(WeavingAdaptor.java:238)
at org.eclipse.equinox.weaving.hooks.WeavingHook.processClass(WeavingHook.java:164)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:616)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:588)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:327)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:402)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:352)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:344)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:573)
... 115 more
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1739394 is a reply to message #1077524] Sun, 31 July 2016 12:34 Go to previous message
I have the same problem
Previous Topic:This version of the rendering library is more recent than your version of ADT plug-in. Please update
Next Topic:cross-project aspects?
Current Time: Sat Jul 26 17:39:19 EDT 2025
Powered by FUDForum. Page generated in 0.29692 seconds
