Home » Modeling » EMF Parsley » Can't create a Parsley Project(New project creation wizard fails)
Can't create a Parsley Project [message #1690611] Sun, 29 March 2015 18:37 Go to next message
When attempting to create a Emf Parsley Dsl based Project the project wizard I get a Problem Opening Wizard Dialog with the message:
The selected wizard could not be started.
org/eclipse/xtext/xtype/XtypeFactory
(java.lang.NoClassDefFoundError: org/eclipse/xtext/xtype/XtypeFactory)
Running on a brand newly installed Eclipse Modeling Tools
Version: Luna Service Release 2 (4.4.2)
Build id: 20150219-0600
Emf Parsley 0.3.0.v20150220-0847
which I installed from the Parsley update site.
Fix was to install the latest Xtext. Should n't the install not require and install it in the first place so it doesn't have to be done manually?
Re: Can't create a Parsley Project [message #1690716 is a reply to message #1690611] Mon, 30 March 2015 15:00 Go to previous messageGo to next message
actually it should automatically install all the Xtext requirements;
which version of Parsley have you tried to install and which update site
have you used? Which Parsley features have you installed? We have
recently released the first official version 0.3.0 and it should install
all the requirements.
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Can't create a Parsley Project [message #1690736 is a reply to message #1690716] Mon, 30 March 2015 18:44 Go to previous messageGo to next message
Features I installed:
Emf Parsley	0.3.0.v20150220-0847	org.eclipse.emf.parsley.feature.feature.group
  Emf Parsley CDO	0.3.0.v20150220-0847	org.eclipse.emf.parsley.cdo.feature.feature.group
  Emf Parsley CDO Developer Resources	0.3.0.v20150220-0847	org.eclipse.emf.parsley.cdo.feature.source.feature.group	Eclipse
  Emf Parsley Developer Resources	0.3.0.v20150220-0847	org.eclipse.emf.parsley.feature.source.feature.group
  Emf Parsley DSL	0.3.0.v20150220-0847	org.eclipse.emf.parsley.dsl.feature.feature.group
  Emf Parsley DSL Developer Resources	0.3.0.v20150220-0847	org.eclipse.emf.parsley.dsl.feature.source.feature.group
  Emf Parsley Examples	0.3.0.v20150220-0847	org.eclipse.emf.parsley.examples.feature.feature.group
  Emf Parsley Examples Developer Resources 	0.3.0.v20150220-0847	org.eclipse.emf.parsley.examples.feature.source.feature.group
  Emf Parsley SDK	0.3.0.v20150220-0847	org.eclipse.emf.parsley.sdk.feature.group
  Emf Parsley SDK Developer Resources	0.3.0.v20150220-0847	org.eclipse.emf.parsley.sdk.source.feature.group
Update Site: Originally used the ".../emf-parsley/updates/0.3" noticed a problem adding the project. Then I tried:
Parsley All updates ".../emf-parsley/updates/" still had a problem so I manually provisioned the Xtext and after that I could add a new parsley project.
I have not tried it with a new installation of Eclipse since I encountered it to reproduce the problem. Perhaps it was just a strange p2 anomolie??
Re: Can't create a Parsley Project [message #1690771 is a reply to message #1690736] Tue, 31 March 2015 03:33 Go to previous messageGo to next message
And you previously added
http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/
as an update site as described here
https://www.eclipse.org/emf-parsley/download.html, haven't you?
Has the checkbox "Contact all update sites..." been checked?
cheers
Lorenzo
Xtext Book:
Re: Can't create a Parsley Project [message #1691056 is a reply to message #1690771] Wed, 01 April 2015 18:51 Go to previous messageGo to next message
Both sites were added per instructions:
Xtext Updates http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/ Enabled
Parsley All updates http://download.eclipse.org/emf-parsley/updates/ Enabled
Believe the checkbox was enabled, but not sure. Besides either way if the dependencies are set for the packages than it should NOT install them if it can't find the deps. Right?
Have not gone back and confirmed this issue with a new install - perhaps this was a p2 anomolie??
Re: Can't create a Parsley Project [message #1691069 is a reply to message #1691056] Thu, 02 April 2015 02:26 Go to previous message
> Xtext Updates
> Enabled
> Parsley All updates
yes, you're right
it could have been an anomaly... I'll check that myself with a new install
cheers
Lorenzo
Xtext Book:
Previous Topic:Executing RecordingCommand using InjectableAdapterFactoryEditingDomain
Next Topic:Add a column to a Table
Current Time: Sat Jul 26 15:22:49 EDT 2025
Powered by FUDForum. Page generated in 0.24291 seconds
