How to avoid that another IDetailPaneFactory will be called [message #1690414] |
Fri, 27 March 2015 05:00 |
In my plugin I got my own view which extends VariablesView.
My plugin has a IDetailPane and a IDetailPaneFactory but it seems that XbaseBreakpointDetailPaneFactory is also listening and tries to cast the variable to a breakpoint.
That will ofcourse throw an exception, shown below. (It happens only ones after starting eclipse, the second time i click a variable in the view no error will show)
Why is this xtext class also listening and how can i avoid the error message?
I would appreciate the help.
!ENTRY org.eclipse.jface 4 2 2015-03-26 15:05:08.154
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.ClassCastException: my.project.debug.Variable cannot be cast to org.eclipse.debug.core.model.IBreakpoint
at org.eclipse.xtext.xbase.ui.debug.XbaseBreakpointDetailPaneFactory.getDetailPaneTypes(XbaseBreakpointDetailPaneFactory.java:42)
at org.eclipse.debug.internal.ui.views.variables.details.DetailPaneManager$DetailPaneFactoryExtension.getDetailPaneTypes(DetailPaneManager.java:94)
at org.eclipse.debug.internal.ui.views.variables.details.DetailPaneManager.getPossiblePaneIDs(DetailPaneManager.java:385)
at org.eclipse.debug.internal.ui.views.variables.details.DetailPaneManager.getPreferredPaneFromSelection(DetailPaneManager.java:285)
at org.eclipse.debug.internal.ui.views.variables.details.DetailPaneProxy.display(DetailPaneProxy.java:109)
at org.eclipse.debug.internal.ui.views.variables.VariablesView.refreshDetailPaneContents(VariablesView.java:1218)
at org.eclipse.debug.internal.ui.views.variables.VariablesView$8.selectionChanged(VariablesView.java:1157)
at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:876)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:178)
at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java:873)
at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect(StructuredViewer.java:1217)
at org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected(StructuredViewer.java:1243)
at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(OpenStrategy.java:265)
at org.eclipse.jface.util.OpenStrategy.access$5(OpenStrategy.java:259)
at org.eclipse.jface.util.OpenStrategy$1$2.run(OpenStrategy.java:440)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:136)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4147)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3764)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
FUDForum. Page generated in 0.03704 seconds
