Home » Eclipse Projects » Advanced Scripting Environment (EASE) » EASE and Application e4(where find examples of ui.)
EASE and Application e4 [message #1639269] Fri, 27 February 2015 09:51 Go to next message
I am new user of Ease, I devlop an application using Eclipse e4 Luna, and I am looking for an example to know how I can insert a script console in my application using application.e4xmi (so how create a part containing all the stuffs).
Thanks a lot.
Antonio
Re: EASE and Application e4 [message #1639426 is a reply to message #1639269] Fri, 27 February 2015 11:30 Go to previous messageGo to next message
cannot help you with the e4xmi, sorry.
But maybe you could ask the question on the e4 forum. Its not specific about the script shell. If you can add a view in compatibility mode then you have everything you need for the script shell.
A good place to start would also be the tutorials by Lars Vogel: http://vogella.com
Re: EASE and Application e4 [message #1639574 is a reply to message #1639426] Fri, 27 February 2015 13:13 Go to previous messageGo to next message
Tanks a lot for your answer.
I have a question why you have the package ....ui.e4?
Re: EASE and Application e4 [message #1639606 is a reply to message #1639574] Fri, 27 February 2015 13:32 Go to previous messageGo to next message
we had an extension to attach scripts to context menus that worked originally only for e4. We ported it and now it works from 3.7 onwards. So the bundle is legacy and should have been deleted some time ago. I'll put it on my agenda
Re: EASE and Application e4 [message #1690036 is a reply to message #1639269] Fri, 27 February 2015 11:30 Go to previous messageGo to next message
Re: EASE and Application e4 [message #1690037 is a reply to message #1690036] Fri, 27 February 2015 13:13 Go to previous messageGo to next message
Re: EASE and Application e4 [message #1690038 is a reply to message #1639574] Fri, 27 February 2015 13:32 Go to previous message
Previous Topic:Can I create scripts that I can run inside the Eclipse Editor?
Next Topic:Can I create scripts that I can run inside the Eclipse Editor?
Current Time: Wed Jul 30 14:21:45 EDT 2025
Powered by FUDForum. Page generated in 0.04939 seconds
