Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Xcore][CDO] Annotations instead of GenModel
[Xcore][CDO] Annotations instead of GenModel [message #1689660] |
Mon, 23 March 2015 23:18  |
Want to generate CDO client code from an Xcore. Instead of going through
the process of creating a GenModel, and manually editing it then
generating my code, it would instead be cleaner to just use annotations
for this.
Example xcore:
@GenModel(copyrightFields="true",
copyrightText="Copyright Verticon, Inc. 2015 All rights reserved.",
editDirectory="/com.verticon.enterprise.cm.edit/src-gen",
editorDirectory="/com.verticon.enterprise.cm.editor/src-gen",
testsDirectory="/com.verticon.enterprise.cm.tests/src-gen",
modelName="CM", prefix="CM",
testSuiteClass="com.verticon.cm.tests.CMAllTests",
runtimePlatform="RCP",
featureDelegation="Reflective",
modulePlugInVariables="CDO=org.eclipse.emf.cdo,org.eclipse.xtext.xbase.lib,org.eclipse.emf.ecore.xcore.lib",
rootExtendsClass="org.eclipse.emf.internal.cdo.CDOObjectImpl",
rootExtendsInterface="org.eclipse.emf.cdo.CDOObject"
package com.verticon.enterprise.cm
class Identity{
id String _id
String name
For the most part it works except for the modulePlugInVariables which
still only set the Module Plug-in Variables to:
Have a hunch I am not setting that Module Plug-in Variables properly.
Anyone have a clue how I can do this in an annotation?
thanks for any help,
John
Re: [Xcore][CDO] Annotations instead of GenModel [message #1689731 is a reply to message #1689660] |
Tue, 24 March 2015 03:45   |
John,
It could be because this is a multi-valued string property and it might
be that this isn't properly handled. Then again, it could be that you
need space as a separator, not comma. Please open a bugzilla with a
small test case...
> through the process of creating a GenModel, and manually editing it
> then generating my code, it would instead be cleaner to just use
> annotations for this.
> Example xcore:
> class Identity{
> id String _id
> String name
> John
Re: [Xcore][CDO] Annotations instead of GenModel [message #1689929 is a reply to message #1689731] |
Tue, 24 March 2015 12:57   |
Ed,
I will experiment some more with your suggestion, but I still have some
questions:
1. Do I have the name of the property correct?
The GenModel UI calls it:
and for the annotation I call it:
I could not use a dash character in the annotation so I just left it
out. That does not seem right though...
2. Can I mix plugin IDs and Java ClassPath values in this multi-valued
string property?
From EMF Second Edition p 353: 'Optionally, when not developing a
plug-in... it is possible to define Java Classpath variables...'
It's that 'Optionally when not' phrase that concerns me.
3. Why does CDO use the CDO=org.eclipse.emf.cdo Java Classpath variable
instead of a plug-in ID? After all I am developing a plugin.
thanks for any clarity,
John
On 03/24/2015 02:45 AM, Ed Merks wrote:
> John,
> small test case...
>> Example xcore:
>> class Identity{
>> id String _id
>> String name
>> John
Re: [Xcore][CDO] Annotations instead of GenModel [message #1689946 is a reply to message #1689929] |
Tue, 24 March 2015 13:51  |
John,
Comments below.
On 24/03/2015 5:57 PM, John E. Conlon wrote:
> Ed,
> some questions:
It should be the actual feature names modelPluginVariables. Aren't you
setting these using the properties view? Or maybe that doesn't work for
this one either...
> string property?
> variable instead of a plug-in ID? After all I am developing a plugin.
The thing before the = is just a name that might be used as a variable,
but I don't think any of those non-plugin things work anymore...
> John
>> John,
>> small test case...
>>> Example xcore:
>>> class Identity{
>>> id String _id
>>> String name
>>> John
Current Time: Wed Jul 30 11:10:17 EDT 2025
Powered by FUDForum. Page generated in 0.04785 seconds
