Home » Language IDEs » ServerTools (WTP) » parsing a jst to a dom tree
parsing a jst to a dom tree [message #168976] Wed, 10 May 2006 19:53 Go to next message
what's the best way to parse a jsp file and produce a dom tree?
This is the way i'm doing it now, but i'm guessing it's not the suitable
one:
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
IFile file = ResourcesPlugin.getWorkspace().getRoot().getFile(new
Path("/test/page.jsp"));
JSPModelLoader l = new JSPModelLoader();
DocumentFactoryForJSP f = new DocumentFactoryForJSP();
DOMModelForJSP jspModel=(DOMModelForJSP)l.newModel();
jspModel.setStructuredDocument((IStructuredDocument)f.create Document());
l.load(file,jspModel);
is there a view other then the content outline useful to display a dom tree?
thanks
Re: parsing a jst to a dom tree [message #168992 is a reply to message #168976] Wed, 10 May 2006 22:34 Go to previous message
On Wed, 10 May 2006 19:53:49 -0400, Alessandro Fredianelli
Like you were to get an IFile, then ...
IModelManager mm = StructuredModelManger.getModelManger();
// every 'get' needs a 'release'
IStrucutredModel sm = mm.getModelForEdit(file);
try {
// you should check instanceof and cast here, etc., here, to be sure model
is what you
// expected, and plan to deal with.
Docuemnt dom = sm.getDocument();
// do your DOM work here
finally {
if (sm != null) {
sm.release();
This DOM is, as you'd expect, sort of special (since for possibly
illformed text) and
is "shared" by others accessing it via the model manager ... which is
usually what you'd
want ... but, that's why the try/finally release is needed (as it is with
any shared resource).
the getModelForEdit and getModelForRead differ only in that those who get
it "for edit" are expected so save it if they are the last one hold it
before released. Where as "for read" means you don't care about saving it
... you just want to display what it is, etc.
Previous Topic:About WTP 1.5RC2 and EJB 3.x
Next Topic:Some KB shortcuts break syntax highlighting in JS
Current Time: Fri Jul 18 19:20:17 EDT 2025
Powered by FUDForum. Page generated in 0.03171 seconds
