Home » Modeling » GMF (Graphical Modeling Framework) » Sequence Diagram with GMF?
Sequence Diagram with GMF? [message #93563] Wed, 17 January 2007 06:32 Go to next message
I must implemente a Sequence diagram in a model tool.
Unfortunately the model already exists as a XML/Castor mapping.....
My Question: Is the any example available to create a Sequence Diagram
with GMF? (ONLY a seqence diagram, not a complete UML designer ;-)
I think I will switch from castor to the EMF if I have a good example
for such diagram type.
greetings
Andreas
Sequence Diagram editor [message #168947 is a reply to message #93563] Mon, 21 January 2008 08:48 Go to previous message
Originally posted by: aritz.galdos.iese.fraunhofer.de
Hello!!!
I have to make alse a sequence diagram editor, and I wnated to know if you
have found something. In this moment, the most important thing for me is the
creation of the life line, I mean, the line which is under each entity in a
sequence diagram. I have some questions related to it:
1.- How can I create them?
____________
?___________?
2.-The lifeline vertical dimension, will be different depending on the
number of relation-invocations beween different entities. Can I define this
dimenstion?
3.-Can I connect two lifelines with different invocations? For example:
____________ ____________
?___________? ?___________?
"FreeGroup" <a.herz@FreeGroup.de> wrote in message
news:eol1i6$3a6$1@utils.eclipse.org...
> greetings
> Andreas
Previous Topic:Querying EMF Resource
Next Topic:Sequence Diagram editor
Current Time: Tue Jul 22 19:15:35 EDT 2025
Powered by FUDForum. Page generated in 0.03473 seconds
