Home » Modeling » Papyrus » Explanation of the Activity Diagram Loop Node(How can the Loop Node be used in a simple way)
Explanation of the Activity Diagram Loop Node [message #1687651] Thu, 19 March 2015 14:47 Go to next message
I am used to a Loop Node that has three sections (Setup, Test and Body), similar to that shown in www.sparxsystems.com/enterprise_architect_user_guide/9.2/standard_uml_models/loop_and_conditional_nodes2.html
Please can someone explain how to use the Loop Node in Papyrus as in this example i.e. in a very simple way
Re: Explanation of the Activity Diagram Loop Node [message #1688180 is a reply to message #1687651] Fri, 20 March 2015 05:23 Go to previous message
Hi Chris,
Papyrus doesn't provide any specific help for defining such LoopNodes. The UML Specification mentions (UML 2.5 16.11.4):
No standard notation is defined for ConditionalNodes, LoopNodes or SequenceNodes
The general idea is that any node inside the LoopNode may be graphically grouped in any way you like, and then you use the Properties page to identify which one(s) is/are in the Setup, Test or Body. If additional grouping is required, then you should have a single "Setup", "Test" and "Body" node (One for each), and add the details inside each (More or less like your example, except that the Body/Setup/Tests are not graphically explicit)
Camille
Previous Topic:Create model from existing uml not working in Luna/Papyrus 1.0.0
Next Topic:[SysML1.4] Generalization shown as deprecated?
Current Time: Sat Jul 26 04:00:35 EDT 2025
Powered by FUDForum. Page generated in 0.03614 seconds
