Re: Running code from embedded orion editor [message #1708717 is a reply to message #1687390] |
Sat, 19 September 2015 05:36  |
I have the same issue.
If I using the example (https://wiki.eclipse.org/Orion/Documentation/Developer_Guide/Long_running_operations_in_services_and_plugins) I can get it to work. But I cannot give a status using the service "orion.page.message".
So I am able to execute a command from a servlet running under Orion using a specific file a s input. But I am not able to set a progress bar (or similar). Nor can I update the folder view with the generated files.
What I would really like to is:
Start a command on a file, and show progress somewhere based on the Orion API (not my own display box).
The command use the input file as input and generate some files as output.
If successful completion of the job update folder view with the generated files (Now I have to do "a manuel refresh").
If errors start a new editor below the main editor and show the log file in here.
Any ideas how to achieve that?
FUDForum. Page generated in 0.24954 seconds
