| read from an xml data source problem [message #168286] |
Wed, 07 June 2006 16:08  |
Originally posted by: sinaizad.gmail.com
hi
i have a problem reading data from an xml file which is over the net on a remote machine(example: http://10clicksurveys.com/FILES/test.xml).
i was wondering if BIRT allows to read from a URL that is not local. if it does why am i getting an error that it cant be retrieved.
what i do is when i make a new data source i choose xml as a data source type and then it asks for the url. after that when i try to make a new data set it asks for an url again and when i enter the above url and click on next, it gives me an error that it cant rerieve data.
here is the detail of the error:
<i>An unexpected internal exception occurred.Please see log for detail.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Designer UI
Plug-in ID:org.eclipse.birt.report.designer.ui
Version:2.0.1
Error Code:Error.GUIException.invokedByUnexpectedException
Error Message:XML data source cannot be retrieved.XML data source file is invalid or the file doesn't exist.</i>
FUDForum. Page generated in 0.04117 seconds
