Home » Archived » BIRT » controling the order of Y series grouping (and legend) of a stacked bar chart
| controling the order of Y series grouping (and legend) of a stacked bar chart [message #122354] |
Wed, 01 February 2006 00:38  |
Originally posted by: rrachamallu.hotmail.com
I have stacked bar chart, with location names for Category(X) Series,
Percentage values for Value(Y) Series. The Optional Y Series Grouping is on
an attribute which can have values of 'High', Medium' and 'Low'.
The problem I have is that, whatever I do, the Y series groupings (and the
legend) are grouped as 'High', 'Low' and 'Medium'. It appears that the Y
series grouping values are being alphabetically sorted.
Is there anyway through which I can have the groupings show up as 'High',
'Medium' and 'Low' instead of 'High', 'Low' and 'Medium'? Any help will be
greatly appreciated.
Reddy
| Re: controling the order of Y series grouping (and legend) of a stacked bar chart [message #125606 is a reply to message #122354] |
Tue, 07 February 2006 16:31   |
I found a workaround for this problem and wanted to share the workaround. If
you have a better way of doing this, please let me know.
I changed my query so that 'High' mapped to 1, 'Medium' mapped to 2 and
'Low' mapped to 3. With this the legend shows up in order (1, 2, 3).
I then implemented the 'beforeDrawLegendEntry' callback method.
function beforeDrawLegendEntry( label, context )
var labelValue = label.getCaption().getValue();
if(labelValue == 1) label.getCaption().setValue("High");
if(labelValue == 2) label.getCaption().setValue("Medium");
if(labelValue == 3) label.getCaption().setValue("Low");
This did the trick for me. The legend in my report now shows up as 'High',
'Medium', 'Low' in that order.
Reddy
"Reddy Rachamallu" <rrachamallu@hotmail.com> wrote in message
news:drph72$cm4$1@utils.eclipse.org...
> on an attribute which can have values of 'High', Medium' and 'Low'.
> the legend) are grouped as 'High', 'Low' and 'Medium'. It appears that the
> Y series grouping values are being alphabetically sorted.
> Thanks
> Reddy
| Re: controling the order of Y series grouping (and legend) of a stacked bar chart [message #168550 is a reply to message #125606] |
Thu, 08 June 2006 11:19   |
This workaround doesn't work so well in that the Legend does not
increase in size to accommodate labels longer in length than the
original "1", "2", and "3" labels.
> Thanks
> Reddy
>> Hi,
>> Thanks
>> Reddy
| Re: controling the order of Y series grouping (and legend) of a stacked bar chart [message #168964 is a reply to message #168550] |
Sun, 11 June 2006 01:21  |
George,
How about using aHigh, bMedium and cLow. And then use the script to
remove the first letter. This should make sure
the labels are has enough space.
Carsten
>> workaround. If you have a better way of doing this, please let me know.
>> and 'Low' mapped to 3. With this the legend shows up in order (1, 2, 3).
>> 'High', 'Medium', 'Low' in that order.
>> Thanks
>> Reddy
>>> Hi,
>>> Series, Percentage values for Value(Y) Series. The Optional Y Series
>>> Grouping is on an attribute which can have values of 'High', Medium'
>>> and 'Low'.
>>> (and the legend) are grouped as 'High', 'Low' and 'Medium'. It
>>> appears that the Y series grouping values are being alphabetically
>>> sorted.
>>> 'High', 'Medium' and 'Low' instead of 'High', 'Low' and 'Medium'? Any
>>> help will be greatly appreciated.
>>> Thanks
>>> Reddy
Current Time: Sat Nov 08 12:49:22 EST 2025
Powered by FUDForum. Page generated in 0.03646 seconds
