Home » Eclipse Projects » Eclipse Platform » Specifying the visibility when contributing to popupMenus [urgent]
Specifying the visibility when contributing to popupMenus [urgent] [message #168530] Wed, 10 December 2003 02:44
Hi All
I want to contribute a new sub menu with an existing pop menu using
"org.eclipse.ui.popupMenus" extension point , and i want to add a sub menu
that appears only if there is a selection in the view (number of selected
objects >0), but the <visibility> item does not have an attribute that
specifiy the number of selected objects , so i restricted the selection to
be of class java.lang.Object like this
<extension
point="org.eclipse.ui.popupMenus">
<viewerContribution
targetID="com.abc.navigation.presentation.view.id"
id="com.abc.ui.popup.NavigationView">
<visibility>
<!-- to be invisible if no object is selected , it can be navigation node
instead of Object -->
<objectClass
name="java.lang.Object">
</objectClass>
</visibility>
<menu
label="static"
path="additions"
id="com.abc.statical.ui.NavigationView.staticSubMenu">
</menu>
</viewerContribution>
Is there a better way to specifiy that i want the submenu to appear if the
number of selection >0 ??????
Thanks , Joe
Previous Topic:Specifying the visibility when contributing to popupMenus
Next Topic:How to debug eclipse in eclipse?
Current Time: Thu Nov 06 01:03:22 EST 2025
Powered by FUDForum. Page generated in 0.03007 seconds
