org.eclipse.graphiti.ui refactoring [message #1684651] |
Wed, 18 March 2015 10:18  |
Hello
As described in this post https://www.eclipse.org/forums/index.php/t/965255/, I want to create an image of the bpmn model on the server side.
Since "org.eclipse.graphiti.ui" is IDE dependent (org.eclipse.ui.views.properties.tabbed, org.eclipse.ui.navigator) I was wondering if there are any plans to move certain parts of the UI bundle into separated bundles?
I was thinking about the "org.eclipse.graphiti.ui.internal.figures" and "org.eclipse.graphiti.ui.internal.parts", maybe others would make sense as well.
"figures" should be possible, "parts" looks a more difficult.
For "figures" the main work would be to replace IConfigurationProviderInternal with IResourceRegistryHolder and IDiagramTypeProvider. Also the reference to IPictogramElementDelegate could be problematic, depending on if "parts" is also moved.
It might even be possible to combine RAP with Graphiti at some point.
What do you think about this?
greets
Flavio
FUDForum. Page generated in 0.05524 seconds
