Home » Eclipse Projects » Eclipse Platform » Upgrading from M2 to M5
Upgrading from M2 to M5 [message #168428] Tue, 09 December 2003 19:20 Go to next message
Originally posted by: james.wowchuk.vcs.com.au
Are there any instructions on doing an upgrade from M2 to M5?
I did a simple unzip to the directory, but got failures on creating Java
PackageExplorer and Hierarchy classes, so I unzipped M2 again and deleted
everything newer than it in the plugins directory.
Do I need to download and unzip M3 & M4 first?
Thanks.
Re: Upgrading from M2 to M5 [message #168438 is a reply to message #168428] Tue, 09 December 2003 20:09 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
Best way is to erase M2 completely and then unzip M5. During development
new versions should be unzipped to a clear directory for best results.
Peter
> Thanks.
Re: Upgrading from M2 to M5 [message #168446 is a reply to message #168438] Tue, 09 December 2003 20:20 Go to previous messageGo to next message
> Peter
>> Thanks.
I second that. The API is in flux for the 3 series and starting from
scratch is a good way to go.
Robert
Re: Upgrading from M2 to M5 [message #168471 is a reply to message #168446] Wed, 10 December 2003 00:55 Go to previous messageGo to next message
what about the workspace dir, could I preserv this? the projects and
configurations set (the export/import at least should work) could be
reused.
Emerson Cargnin
http://echofloripa.sytes.net
"Robert" <bobx@linuxmail.org> escreveu na mensagem
news:br5s7k$h5u$1@eclipse.org...
> > Peter
Java
deleted
> >> Thanks.
> Robert
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.548 / Virus Database: 341 - Release Date: 6/12/2003
Re: Upgrading from M2 to M5 [message #168587 is a reply to message #168471] Wed, 10 December 2003 04:18 Go to previous messageGo to next message
Originally posted by: marcus.edwards.digitalsteps.com
"Emerson Cargnin" <echofloripa@bol.com.br> wrote in message
news:br68h5$sto$1@eclipse.org...
> reused.
You may be able to. Give the following a try:
1. Backup the workspace directory to a location outside the eclipse
installation root, call this
<workspace-location>.
2. Install M5
3. When launching the new Eclipse installation, add the command-line
argument -data <workspace-location>
to have Eclipse use your original workspace directory.
This is generally good practice as it means you can complete a clean install
/ upgrade of eclipse without loosing
project settings etc.
HTH,
Marcus
Re: Upgrading from M2 to M5 [message #168804 is a reply to message #168587] Wed, 10 December 2003 13:15 Go to previous messageGo to next message
Originally posted by: emerson.tre-sc.gov.br
Just clear some ideas to me :
- Do I need to use -data option just in the first time?
- Why in linux it always use the workspace at the home dir and linux the
default is to use the workspace inside the eclipse dir?? Besides, in
linux, if I have the eclipse dir not in the user's home the workspace is
put inside eclipse dir, as in windows.
> > reused.
> 2. Install M5
> HTH,
> Marcus
Re: Upgrading from M2 to M5 [message #171972 is a reply to message #168428] Thu, 18 December 2003 11:27 Go to previous message
Originally posted by: John_Arthorne.oti.com_
Upgrade instructions are always found in the readme file. See
eclipse/readme/readme_eclipse.html, section 5.
> Thanks.
Previous Topic:Unsupported "platform:" protocol
Next Topic:REPOST: Plugin parameters
Current Time: Thu Nov 06 13:10:17 EST 2025
Powered by FUDForum. Page generated in 0.04701 seconds
