Home » Eclipse Projects » GEF » Chaning properties don't make dirty
Chaning properties don't make dirty [message #168340] Tue, 15 February 2005 03:45 Go to next message
Hi! I need a little hint again!
This isn't 100% GEF specific I know, sorry.
My model objects implement a few properties with IPropertySource. Most of
these properties don't
have any visual effect, like descriptions for example. Now, if I change a
description property,
my editor doesn't get dirty and I can't save. I have to move one of the
figures a bit to make
saving possible.
How can this be solved?
Re: Chaning properties don't make dirty [message #168403 is a reply to message #168340] Tue, 15 February 2005 14:54 Go to previous messageGo to next message
Maybe if you call firePropertyChange(PROP_DIRTY) in your IEditorPart, it
will become marked as dirty?
> saving possible.
Re: Chaning properties don't make dirty [message #168420 is a reply to message #168340] Tue, 15 February 2005 18:25 Go to previous messageGo to next message
Originally posted by: kevinlouisnospam.hotmail.com
Are you using the Command to make the changes? The CommandStack#isDirty
will handle it. If not, you have to override the EditPart$isDirty function.
"Roger Villars" <roger.villars@mimacom.ch> wrote in message
news:cuscim$u7l$1@www.eclipse.org...
> saving possible.
Re: Chaning properties don't make dirty [message #168434 is a reply to message #168420] Tue, 15 February 2005 19:27 Go to previous messageGo to next message
>>saving possible.
when i implemented IPropertySource it seems to automatically use the
stack somehow. So if he is having an issue, maybe he is not processing
the dirty event properly!?
CL
Re: Chaning properties don't make dirty [message #168442 is a reply to message #168340] Tue, 15 February 2005 23:42 Go to previous message
GEF provides an undoable propertysheet entry. This entry creates commands
which dirty the command stack, and consequently the editor.
I think the method is GEFPlugin#createUndoablePropertySheetEntry() Search
for references to this method.
"Roger Villars" <roger.villars@mimacom.ch> escreveu na mensagem
> saving possible.
Previous Topic:Alignment Retarget Actions
Next Topic:Snap to grid on creation?
Current Time: Sat Jul 19 04:27:39 EDT 2025
Powered by FUDForum. Page generated in 0.12240 seconds
