| WrapLabel does not display on Mac [message #168048] |
Mon, 14 January 2008 10:26  |
Originally posted by: ft.zimmermann.web.de
I've got a little gmf plugin working on my xp machine. Transfering the
plugins to my brandnew mac the following feature occurs:
In a WrapLabel I can enter multiline Text as on XP, but only the first
line is displayed on Mac OS X 10.5, whereas XP displays all lines.
The label is inside a label which has a grid layout.
I tried to change the gridData of the iner label to everything that looks
like more space to me, but nothing changed. Just to say it again: This
construct works neatly on XP.
| Re: WrapLabel does not display on Mac [message #168280 is a reply to message #168219] |
Tue, 15 January 2008 11:19  |
Frank,
Sounds like this is definitely a bug if it can be reproduced with the
Logic Example. I would suggest raising a bugzilla. However, it would
be best to try this with a pure GEF example to see if the issue is with
GEF or GMF before raising the bugzilla. The GEF Logic Example can be
retrieved from CVS as well. It is located in the /cvsroot/tools
repository in the org.eclipse.gef package.
Cherie
Frank Zimmermann wrote:
> I instaled the Logic example from the cvs.
> The behavior is even worse. A note can have more hat one line, but now
> it seems that the Editor cell and the label do not compute the size
> correctly.
> The cell shows 1 1/3 and the labelview definitely only 1 line
FUDForum. Page generated in 0.04724 seconds
