Home » Language IDEs » C / C++ IDE (CDT) » multiple targets with managed project cdt
multiple targets with managed project cdt [message #163372] Tue, 07 February 2006 07:40 Go to next message
Originally posted by: guido009.gmx.de
it is possible to define multiple targets with a managed c++ project? I
don't know how it works.
Guido
Re: multiple targets with managed project cdt [message #168226 is a reply to message #163372] Sun, 16 April 2006 17:57 Go to previous messageGo to next message
After searching for the answer for this same question for hours I
managed to find out that:
This can not be done and it is against the concept of Managed Make
projects - one binary per project!
If you want multiple binaries then you'll need to use a Standard Make
project or create multiple Managed Make projects each for every
individual binary you want to have (and use inter-project dependencies)
or for the extremes - write your own Makefile Builder (and then please
put it somewhere on the net, you are not the only one that wants to have
it).
gw
Guido wrote:
> Hello,
> Thanks
> Guido
Re: multiple targets with managed project cdt [message #715231 is a reply to message #163372] Fri, 12 August 2011 17:05 Go to previous message
You can accomplish this sort of result by making a separate build configuration for each executable and then excluding the other files with the main() function from each configuration.
Previous Topic:CDT Install Halted
Next Topic:Eclipse C/C++ Remote Debugging
Current Time: Sat Sep 27 02:45:35 EDT 2025
Powered by FUDForum. Page generated in 0.04162 seconds
