Home » Eclipse Projects » Subversive » BPEL Installation Problem
BPEL Installation Problem [message #1655776] Sat, 07 March 2015 02:24 Go to next message
Hi Everyone ,,
I need to install BPEL on eclipse but I have a problem init ..
When I go to install new software and set the location: download.eclipse.org/bpel/site/
It shows me a red cross and msg.: " Couldn't find download.eclipse.org/bpel/site/
Copy_www2.0zz0.com/2015/03/07/10/922945446.png
I tried to install multi packages of eclipse but still the problem is not solved, so what do you think Sad ?
Thank you for your cooperation !
Re: BPEL Installation Problem [message #1673066 is a reply to message #1655776] Sat, 14 March 2015 02:41 Go to previous messageGo to next message
Any help please Sad
Copy this link please to know the problem Sad
[Updated on: Sat, 14 March 2015 02:45] by Moderator
Re: BPEL Installation Problem [message #1681261 is a reply to message #1673066] Tue, 17 March 2015 04:34 Go to previous messageGo to next message
Hello, this is not BPEL forum, but anyway, I checked your problem screenshot and can suggest you try following:
1) check the URL you entered, in order to ensure its correctness
2) if the URL is as following: http://download.eclipse.org/bpel/site/ , then you should open this URL in browser. There you'll see several different update sites. Choose one, and use its URL in Eclipse.
Hope it helps.
P.S.
Anyway, all the future questions you better ask at BPEL forum, since there is a higher chance to get a helpful answer regarding the tool.
[Updated on: Tue, 17 March 2015 04:37] by Moderator
Re: BPEL Installation Problem [message #1681262 is a reply to message #1673066] Tue, 17 March 2015 04:34 Go to previous messageGo to next message
Hope it helps.
P.S.
Re: BPEL Installation Problem [message #1684363 is a reply to message #1681262] Wed, 18 March 2015 07:50 Go to previous message
Thank u for your replay but still the problem is not solved ..
Yes, the URL is corrected Sad
[Updated on: Thu, 19 March 2015 00:38] by Moderator
Previous Topic:.settings folder
Next Topic:SVNKit 1.8.9
Current Time: Sat Jul 26 19:26:57 EDT 2025
Powered by FUDForum. Page generated in 0.04016 seconds
