| WTP 1.0 to 1.5 API/extension points migration guide [message #167894] |
Fri, 28 April 2006 13:40   |
Eclipse User  |
Anyone know of a WTP 1.0 to 1.5 API/extension points migration guide ?
I'm currently struggling with porting from 1.0 XML handling to WTP 1.5.
I get no warning nor compile errors; but nothing is working ;(
So I have the feeling some extension point has changed name or behavior
so any tips appreciated ;)
/max
| Re: WTP 1.0 to 1.5 API/extension points migration guide [message #168123 is a reply to message #168014] |
Sun, 30 April 2006 13:01    |
Eclipse User  |
On Sat, 29 Apr 2006 10:47:33 -0400, Max Rydahl Andersen
<max.andersen@jboss.com> wrote:
> so, I figured it out and it is *very* suttle!
> Can anyone tell me why ? And if it is so, why doesn't something complain
> hard when a content-type id contains dot's ?
Max, I don't think its just content type IDs, it should be true for any
extension ID.
For details, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=128866
Funny thing is ... this was the whole reason for the 'a' part of 3.2M5a.
And ... as part of the "workaround" was that the new namespace naming rules
should have an effect only if you update your plugin to say
<?eclipse version="3.2"?>
That is, ID's with dot's should still work if the PI at top of eclipse
plugin
still says <?eclipse version="3.2"?>
(And, BTW, the platform team would say the rule of "no dot's in ID names"
is not not new ... just a new
enforcement of them :)
So, if you did not use 3.2 in PI, that might be worth opening a new bug
related to bug 128866.
If you did use 3.2, then you were not only breaking original syntax rules
on IDs, but you
even asked for the new enforcement of them :)
| Re: WTP 1.0 to 1.5 API/extension points migration guide [message #168179 is a reply to message #168123] |
Mon, 01 May 2006 10:05    |
Eclipse User  |
>> complain hard when a content-type id contains dot's ?
> extension ID.
That is the bug thingy I remembered.
> rules
I did not update any plugin.xml to 3.2.
> plugin
> names" is not not new ... just a new
Which i'm quite fine with; but they could be good sports and make the PDE
editor warn about them ;)
> rules on IDs, but you
blah ;)
i'll open a bug.
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
FUDForum. Page generated in 0.04162 seconds
