Home » Eclipse Projects » Nebula » PGroup GroupStrategies
PGroup GroupStrategies [message #16807] Fri, 10 November 2006 11:44 Go to next message
Howdy,
I just stumbled onto the Nebula page and was excited to see several
widgets which are exactly what I've been looking for! This is very cool.
Most immediately, I need PGroup.
As for the different GroupStrategys...are there any plans to have the
SimpleGroupStrategy (or another new GroupStrategy) emulate the behavior of
the SWT widget "Group", which draws a round-rectangle around the entire
composite? Or perhaps there is a flag I can set to do this already and I
just haven't discovered it yet?
Also, what's up with the little box that occasionally appears in the upper
left hand corner of a PGroup? I presume this is just a bug that has to do
with rendering the toggle...
Thanks for starting this project up -- I'm eager to put this stuff to use.
-dave
Re: PGroup GroupStrategies [message #16814 is a reply to message #16807] Fri, 10 November 2006 12:15 Go to previous message
Hi Dave,
Glad you like PGroup.
I don't have any plans to create any new strategies at the moment.
They're not that hard to write, especially if you write one without many
options.
The little box that shows up is actually a focus rectangle. There's a
bug with SWT 3.2 that is causing them to be drawn incorrectly. If you
have 3.3 it should look fine (the focus rect should surround the
toggle). Hopefully the fix will be back ported to 3.2.x.
-Chris
Dave wrote:
> Howdy,
> -dave
Re: PGroup GroupStrategies [message #568487 is a reply to message #16807] Fri, 10 November 2006 12:15 Go to previous message
Hi Dave,
options.
-Chris
Dave wrote:
> Howdy,
> -dave
Previous Topic:PGroup GroupStrategies
Next Topic:Grid Plans
Current Time: Fri Jul 18 07:29:53 EDT 2025
Powered by FUDForum. Page generated in 1.04618 seconds
