| Using workspace as Plug In [message #167745] |
Mon, 28 August 2006 06:51  |
Originally posted by: murthy_bvr.yahoo.com
Though this is not directly related to Eclipse, I thought I might find an
answer here.
I have been working with RSA (Rational Software Architect). The tool
currently does not allow a transformation from UML to WSDL. For that we
have to download a samples project and install it in our workspace and run
it as a plugin.
Here is a link from IBM that tells us how to do it -
http://www-128.ibm.com/developerworks/rational/library/06/04 11_johnston/
In one of the steps of installation the link says "Now that you have
imported them, these samples are included as plug-in projects in your
current workspace, which means that you cannot directly execute the
transformations. To use the transformations, you have to start a runtime
workbench, ensuring that the new plug-ins are included in its
configuration. Once the new workbench is running, you can either import
existing models into its workspace or create new models to work on. "
I am however, unable to understand how to get that samples run as a plugin?
I have not worked on plugins and stuff so I am not sure how to get this
thing working.
Any help in this regard is greatly appreciated.
Murthy.
| Re: Using workspace as Plug In [message #168019 is a reply to message #167745] |
Tue, 29 August 2006 02:44  |
You must have basic knowledge of how eclipse works to get this done.
Have you tried on of the sample plugin examples found in the eclipse
documentation?
Try this one:
http://help.eclipse.org/help32/topic/org.eclipse.platform.do c.isv/guide/firstplugin.htm
Focus especialy on:
http://help.eclipse.org/help32/topic/org.eclipse.platform.do c.isv/guide/firstplugin_run.htm
Yes I know - it is a "hello world" example but 90% of what you must know
to run you plugins is presented in this example.
kiril mitov
Murthy wrote:
> answer here.
> it as a plugin.
> thing working.
> Regards,
> Murthy.
FUDForum. Page generated in 0.08664 seconds
