Home » Language IDEs » ServerTools (WTP) » How can I update-to 1.0.2 ?
How can I update-to 1.0.2 ? [message #168005] Sat, 29 April 2006 03:32 Go to next message
Originally posted by: zousey.hotmail.com
well an issue as they are many version of webtools,and i have an older
version, how can I uptade it to
wtp-all-in-one-sdk-R-1.0.2-200604200208-win32.zip(md5) ?
Re: How can I update-to 1.0.2 ? [message #168117 is a reply to message #168005] Sun, 30 April 2006 12:37 Go to previous messageGo to next message
> Thanks
The purpose of the "all in one" distributions is that they provide
a "fresh" version of everything (WTP that is, and its prereq's).
This works really well for anyone using just WTP. Once you have a fresh
installation,
you can "point" it to your old worksapce (either with -data <workspace
directory> or
I think there's some dialog that pop's up, if you prefer that method.
But, what if you have other things installed? You naturally want to "keep"
those.
It is never a good idea to try and "overlay" one zip file on top of an
existing install.
Almost never works, with Eclipse plugins.
One strategy some people use is to "keep their zips" of any and all
features they use
in some handy directory (or, sequence of directories) -- that would be
WTP, its pre-reqs,
and any other "extra" plugins they obtain elsewhere -- and then when
any one of those sets are desired to be updated, they
unzip them all again to a fresh directory. (And, naturally, then "point
to" their
old workspace, using -data, or the pop-up wizard). So, the "all in one"
would still be
useful in this case .. but you also need the zips of what ever else you
installed.
Another strategy is to use Update Manager ... should be ready soon for
1.0.2. I'll announce to this
list when it is.
Re: How can I update-to 1.0.2 ? [message #168901 is a reply to message #168117] Wed, 10 May 2006 09:43 Go to previous messageGo to next message
>> Thanks
If it can help, I found very very useful what described in these articles:
http://blog.exis.com/colin/archives/2004/12/23/managing-plug ins-in-eclipse/
http://www.javalobby.org/java/forums/t18678.html
I think that is what David Williams is talking about in his replay, here.
> list when it is.
About this, I'm experimenting a strange behavior using the Update
Manager. In few words I cannot get it to work for updating any of the
Platform component, like WTP.
I started with a fresh installation of the WTP-all-in-one 1.0.1, then
when 1.0.2 was out I tried to update to the new version (following the
update instruction available in the web site), but during the download
my network connection hanged up (it stopped working even the ping
command!), then after few minutes the update Manager said there was a
network error and was unable to download some files. After closing the
dialog, the network restarted working.
Did someone find similar problems?
Fabio Da Soghe
Re: How can I update-to 1.0.2 ? [message #169012 is a reply to message #168901] Wed, 10 May 2006 23:09 Go to previous messageGo to next message
On Wed, 10 May 2006 09:43:21 -0400, Fabio Da Soghe
I haven't seen this, exactly, but I do know update manager is not very
robust in handling
"bad servers" or "bad connections" ... did you happen to be using a
mirror? Which ... depending
on the exact time you tried, may have had only part of the content?
Certainly you'd want to try other mirrors, or eclipe.org directly.
If you continue to repeatedly see
such problems, feel free to open a bug report with as much detail as you
can include.
But ... now that there's a 1.0.2 all-in-one .. you may just want to use
that instead?
Unless you are just experimenting or helping us test.
Re: How can I update-to 1.0.2 ? [message #169066 is a reply to message #169012] Thu, 11 May 2006 06:21 Go to previous message
> robust in handling
I made 3 tests: a local mirror (I mean, same country - Italy), another
mirror (SWITCH, which I always have found very reliable for other
things, like downloading from sourceforge) and eclipse.org directly.
Same result as I described.
> can include.
I'll do my best. Could you point me at where I can find some stack
trace, error log, etc? Is it sufficient the log I get from the Error Log
view (if there's any, I didn't check)?
> that instead?
Yes, I did that. But it's quite frustrating having a full-featured
update system and not being able to use it.
Thank you for your interest.
Fabio
Previous Topic:One war, several projects.
Next Topic:Maven2Eclipse and WTP
Current Time: Sat Jul 26 08:49:41 EDT 2025
Powered by FUDForum. Page generated in 0.04702 seconds
