Home » Eclipse Projects » GEF » how to get the location of an image in a label?
how to get the location of an image in a label? [message #167922] Fri, 11 February 2005 23:15 Go to next message
Originally posted by: yabing.crimsonlogic.com
I am trying to create connections between two labels, which are decorated
with images. I use the following method to create the labels:
Label label = new Label("text", new Image(d, "d:\\mapitem_field.gif"));
now I want to get the location of the image in the label so that I can
make it as the anchor point for the connection between the labels.
currently I am using the follwing method to get the location:
Rectangle r = getOwner().getBounds().getCopy();
// return the rectangel of the label
return r.getRight();
can anyone tell me how I can revise the code above to get the location of
the image in the label? Thanks so much!
Yabing
Re: how to get the location of an image in a label? [message #167941 is a reply to message #167922] Sat, 12 February 2005 07:11 Go to previous messageGo to next message
Yabing,
Without thinking too much, this should give you the bounds of the image.
Rectangle r = ((Label)getOwner()).getIcon().getBounds();
Hope this helps,
Brian.
yabing chen wrote:
> Label label = new Label("text", new Image(d, "d:\mapitem_field.gif"));
> Yabing
Re: how to get the location of an image in a label? [message #168051 is a reply to message #167941] Sun, 13 February 2005 21:25 Go to previous messageGo to next message
Hi Brian,
instead of org.eclipse.draw2d.geometry.Rectangle, the method
((Label)getOwner()).getIcon().getBounds() returns an instance of
org.eclipse.swt.graphics.Rectangle, which always returns x and y values of
0.
so i still don't know how I can get the position of the image rectangle
object.
Yabing
Brian Fernandes wrote:
> Yabing,
> Hope this helps,
> Brian.
> yabing chen wrote:
>> Hi,
>> Label label = new Label("text", new Image(d, "d:mapitem_field.gif"));
>> Yabing
Re: how to get the location of an image in a label? [message #168074 is a reply to message #168051] Sun, 13 February 2005 22:12 Go to previous messageGo to next message
yabing,
Sorry, I checked the code right now and I you should use
Label#getIconBounds
That would make it
Rectangle r = ((Label)getOwner()).getIconBounds();
Hope that checks out :)
Brian.
yabing chen wrote:
> Hi Brian,
> 0.
> object.
> Yabing
>> Yabing,
>> Hope this helps,
>> Brian.
>> yabing chen wrote:
>>> Hi,
>>> Yabing
Re: how to get the location of an image in a label? [message #168106 is a reply to message #167922] Sat, 12 February 2005 02:33 Go to previous messageGo to next message
label.getIconBounds()
"yabing chen" <yabing@crimsonlogic.com> wrote in message
news:cujvtv$eju$1@www.eclipse.org...
> Yabing
Re: how to get the location of an image in a label? [message #168168 is a reply to message #168074] Mon, 14 February 2005 01:45 Go to previous message
Hi Brian,
Yeah, Now it is ok. thanks so much!
Yabing
> yabing,
> Label#getIconBounds
> That would make it
> Brian.
> yabing chen wrote:
>> Hi Brian,
>> 0.
>> object.
>> Thanks,
>> Yabing
>>> Yabing,
>>> Hope this helps,
>>> Brian.
>>> yabing chen wrote:
>>>> Hi,
>>>> Yabing
Previous Topic:My DirectEdit works only if I override the DirectEditManager.commit() method?!
Next Topic:draw2d: mousedragged and draw rectangle
Current Time: Sat Jul 19 01:42:08 EDT 2025
Powered by FUDForum. Page generated in 0.03783 seconds
