Home » Eclipse Projects » GEF » Standalone shapes demo
Standalone shapes demo [message #15244] Tue, 23 July 2002 13:32 Go to next message
In an attempt to understand GEF better, I'm trying to create a standalone
shapes app. My first attempt has been to just wrap the ShapeEditor with
some really simple:
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
ShapeEditor editor = new ShapeEditor();
editor.createPartControl(shell) ;
This seems pretty promising, but I'm getting the following exception:
at
com.ibm.etools.gef.ui.parts.GraphicalEditor.hookGraphicalVie wer(GraphicalEdi
tor.java:113)
at
com.ibm.etools.gef.ui.parts.GraphicalEditor.createGraphicalV iewer(GraphicalE
ditor.java:43)
at
com.ibm.etools.gef.ui.parts.GraphicalEditorWithPalette.creat ePartControl(Gra
phicalEditorWithPalette.java:42)
at com.indigoegg.studio.gui.swt.TestDisplay.foo(TestDisplay.jav a:29)
at com.indigoegg.studio.gui.swt.TestDisplay.main(TestDisplay.ja va:21)
Exception in thread "main"
Can anyone steer me in the right direction?
Thanks!
M
Re: Standalone shapes demo [message #15278 is a reply to message #15244] Tue, 23 July 2002 12:28 Go to previous messageGo to next message
Originally posted by: none.ibm.com
This will not work. GEF requires Eclipse Workvench to be present. You will
end up recreating part the workbench if you really want the examples to work
properly.
"Matt Ho" <matt@indigoegg.com> wrote in message
news:ahk211$5dd$1@rogue.oti.com...
> some really simple:
> at
> tor.java:113)
> at
> ditor.java:43)
> at
> Thanks!
> M
Re: Standalone shapes demo [message #15341 is a reply to message #15278] Tue, 23 July 2002 14:00 Go to previous messageGo to next message
Does this mean that I can't use GEF outside of the workbench or just that I
need to do a lot of work to get it to work outside the workbench? Is there
a good starting point to figure out what I need to do to make the thing work
standalone?
Any input would be appreciated :D
M
"Randy Hudson" <none@ibm.com> wrote in message
news:ahk2ga$5qt$1@rogue.oti.com...
will
work
> properly.
standalone
> > some really simple:
> > at
> > tor.java:113)
> > at
> > ditor.java:43)
> > at
> > Thanks!
> > M
Re: Standalone shapes demo [message #15407 is a reply to message #15341] Wed, 24 July 2002 06:10 Go to previous messageGo to next message
Originally posted by: i.seipp.science-computing.de
Is it possible to have a "stripped-down" gef
which includes only the minimal part of eclipse (maybe workbench +
draw2d),
ideally in pure Java?
What would be needed for that?
Ingo
> standalone?
> M
> will
> work
> > properly.
> standalone
> > > some really simple:
> > > at
> > > tor.java:113)
> > > at
> > > ditor.java:43)
> > > at
> > > Thanks!
> > > M
Re: Standalone shapes demo [message #16222 is a reply to message #15407] Mon, 05 August 2002 15:46 Go to previous messageGo to next message
> draw2d),
There have been a number of discussions about this on eclipse.tools.
I'd start by searching for those. My recollection is that there is a
minimal number of plugins that you need, plus you will have to change
one of them so that it doesn't register some IDE-specific menus with the
platform. After that, you're good-to-go.
Dave
Dave Orme
Advanced Systems Concepts
http://www.asc-iseries.com
Re: Standalone shapes demo [message #16314 is a reply to message #16222] Thu, 08 August 2002 05:15 Go to previous messageGo to next message
if you want GEF without workbench, I guess you should start with Draw2d
and add all editing-functionality by yourself.
David J. Orme wrote:
> Ingo Seipp wrote:
>> Is it possible to have a "stripped-down" gef which includes only the
>> draw2d),
> There have been a number of discussions about this on eclipse.tools. I'd
> Dave
Re: Standalone shapes demo [message #16772 is a reply to message #16314] Tue, 13 August 2002 05:13 Go to previous message
Originally posted by: Bram.Stieperaere.REMOVEskynet.be
I posted a standalone version of the Logic demo a few weeks ago. see the
wiki for more info.
at http://eclipsewiki.swiki.net/50#logicexamplestandalone
the main() is in the LogicSAMain class
for the list of jars to add, check the wiki.
The logic example "as is" cannot run as a standalone application, because
the lookup of the resourcebundle
goes via the API for plugins. So I "patched" the LogicResources class to go
to the resourcebundle directly. For the rest the application runs perfeclty
in standalone.
Bram
"Marco van Meegen" <marco@mvmsoft.de> wrote in message
news:3D5236CE.5070108@mvmsoft.de...
> >> draw2d),
> > Dave
Previous Topic:[Draw2d] how do i create a non transparent figure
Next Topic:Tabs and Tabbed items
Current Time: Sat Jul 19 00:06:18 EDT 2025
Powered by FUDForum. Page generated in 0.68879 seconds
