Home » Eclipse Projects » GEF » Moving Figure, SHIFT or CTRL key is down
Moving Figure, SHIFT or CTRL key is down [message #167523] Wed, 09 February 2005 09:29 Go to next message
Originally posted by: jsk_lam.hotmail.com
On moving an figure object with the mouse, I need to test to see
if the SHIFT or CTRL key is pressed down , can someone show
me how to test it? Also, where or which notification method should
I look into for updating the information of the figure being moved?
SL
Re: Moving Figure, SHIFT or CTRL key is down [message #167538 is a reply to message #167523] Wed, 09 February 2005 09:43 Go to previous messageGo to next message
public class CreationTool
extends TargetingTool
protected void updateTargetRequest() {
CreateRequest req = getCreateRequest();
if (isInState(STATE_DRAG_IN_PROGRESS)) {
Point loq = getStartLocation();
Rectangle bounds = new Rectangle(loq, loq);
bounds.union(loq.getTranslated(getDragMoveDelta()));
req.setSize(bounds.getSize());
req.setLocation(bounds.getLocation());
req.getExtendedData().clear();
if (!getCurrentInput().isAltKeyDown() && helper != null) {
PrecisionRectangle baseRect = new PrecisionRectangle(bounds);
PrecisionRectangle result = baseRect.getPreciseCopy();
helper.snapRectangle(req, PositionConstants.NSEW,
baseRect, result);
req.setLocation(result.getLocation());
req.setSize(result.getSize());
} else {
req.setSize(null);
req.setLocation(getLocation());
Mostly it depends in which class you want to check key state
"slam" <jsk_lam@hotmail.com> wrote in message
news:cud6n8$jim$1@www.eclipse.org...
> Thanks
> SL
Re: Moving Figure, SHIFT or CTRL key is down [message #167561 is a reply to message #167523] Wed, 09 February 2005 14:46 Go to previous messageGo to next message
This is already done for you. CTRL turns a drag into a "clone". Shift
restricts motion to 45 desgrees.
"slam" <jsk_lam@hotmail.com> escreveu na mensagem
> Thanks
> SL
Re: Moving Figure, SHIFT or CTRL key is down [message #167592 is a reply to message #167561] Wed, 09 February 2005 16:21 Go to previous messageGo to next message
Well, what I need to do is when the user moves the figure,
I need to move all its child nodes along (only when the SHIFT
key is pressed). That is, I need to update all the child node's
location when the parent node is moved. How do I do it?
How to register or use the TargetingTool with the figure?
Thanls
SL
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cudpas$ddj$1@www.eclipse.org...
> > Hi,
> > Thanks
> > SL
Re: Moving Figure, SHIFT or CTRL key is down [message #167598 is a reply to message #167538] Wed, 09 February 2005 16:21 Go to previous messageGo to next message
Thanls
SL
"b00lean" <kk@cleverlance.com> wrote in message
news:cud7jj$nqi$1@www.eclipse.org...
> baseRect, result);
> } else {
> req.setSize(null);
> > Hi,
> > Thanks
> > SL
Re: Moving Figure, SHIFT or CTRL key is down [message #167629 is a reply to message #167592] Wed, 09 February 2005 17:16 Go to previous messageGo to next message
From your drag tracker, you can call getCurrentInput().isShiftKeyDown().
news:cudutd$876$1@www.eclipse.org...
> Thanls
> SL
>> > Hi,
>> > Thanks
>> > SL
Re: Moving Figure, SHIFT or CTRL key is down [message #167697 is a reply to message #167629] Thu, 10 February 2005 01:45 Go to previous messageGo to next message
Hi Randy,
How do I get the drag tracker notification?
SL
news:cue23s$m37$1@www.eclipse.org...
> > Thanls
> > SL
> >> > Hi,
> >> > Thanks
> >> > SL
Re: Moving Figure, SHIFT or CTRL key is down [message #167914 is a reply to message #167629] Fri, 11 February 2005 21:17 Go to previous messageGo to next message
Hi Randy,
I am not using the Drag Tracker at all. Is there a way that I can found
out whether the SHIFT key is pressed (from any code)?
SL
> > Thanls
> > SL
> >> > Hi,
> >> > Thanks
> >> > SL
Re: Moving Figure, SHIFT or CTRL key is down [message #168036 is a reply to message #167914] Sun, 13 February 2005 20:15 Go to previous message
So, you are using just draw2d? The mouse event should have as much
information in it as an SWT mouse event. Determining if the SHIFT key is
down is the same as it is in SWT. You could also just look at the code for
the method I pointed you to.
news:cujovr$ntv$1@www.eclipse.org...
> Hi Randy,
> Thanks
> SL
>> > Thanls
>> > SL
>> >> Shift
>> >> > Hi,
>> >> > Thanks
>> >> > SL
Previous Topic:Selecting connections
Next Topic:Automatic Layouts
Current Time: Sat Jul 19 02:32:48 EDT 2025
Powered by FUDForum. Page generated in 0.04869 seconds
