Home » Language IDEs » ServerTools (WTP) » high CPU usage on BP
high CPU usage on BP [message #167502] Tue, 25 April 2006 05:12 Go to next message
I just came across an issue that when a breakpoint is hit, CPU usage jumps
to >90% . Before I continue investigating this I wanted to know if anyone
else experienced this.
I'm running eclipse 3.2 RC1 + WTP M6 on Win XP.
Zohar.
Re: high CPU usage on BP [message #167600 is a reply to message #167502] Wed, 26 April 2006 04:16 Go to previous messageGo to next message
I have the same issue with u. It does not stop at the break point.
I am using Eclipse 3.2 RC1 & WTP 1.5RC1
Re: high CPU usage on BP [message #167647 is a reply to message #167502] Wed, 26 April 2006 15:45 Go to previous messageGo to next message
Originally posted by: ifedorenko.rogers.com
Yes, I saw this problem. In my case, this happened when the suspected
thread was not visible in Debug view and the problem was going away when
I scrolled Debug view to see all stack frames of the suspended thread.
This Eclipse bug was fixed as part of solution for bug 120200 (post RC1).
Zohar wrote:
> Zohar.
Re: high CPU usage on BP [message #167664 is a reply to message #167647] Thu, 27 April 2006 01:36 Go to previous messageGo to next message
But did you also see the CPU soaring?
"Igor Fedorenko" <ifedorenko@rogers.com> wrote in message
news:e2oil0$ce3$1@utils.eclipse.org...
> thread was not visible in Debug view and the problem was going away when I
> scrolled Debug view to see all stack frames of the suspended thread. This
> Zohar wrote:
>> Hi,
>> jumps to >90% . Before I continue investigating this I wanted to know if
>> anyone else experienced this.
>> Thanks,
>> Zohar.
Re: high CPU usage on BP [message #167742 is a reply to message #167664] Thu, 27 April 2006 12:13 Go to previous message
Yes, CPU usage was 100%.
>> Zohar wrote:
>>> Hi,
>>> Thanks,
>>> Zohar.
Previous Topic:1.5M6 and Processing Dirty Regions
Next Topic:Exception: org.apache.jasper.JasperException: /Result.jsp(10,0)
Current Time: Tue Jul 22 02:22:47 EDT 2025
Powered by FUDForum. Page generated in 0.43912 seconds
