Home » Newcomers » Newcomers » newbie: very simple problem strange error
newbie: very simple problem strange error [message #167628] Sun, 27 August 2006 22:29 Go to next message
Originally posted by: go.away.com
hi-
i keep getting this message when i use shell
Syntax error on token";",{ expected after this token.
the error is on line 15.
i had such good productivity and than this.
any help figuring out why i am getting this syntax error
is a huge help.
thanks,
jim
package bcalc;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.SWT;
public class Foo {
public static void main(String args[]) {
Shell shell2 = new Shell();
VendorListViewer vendorListViewer = new
VendorListViewer("bb",shell2,SWT.V_SCROLL);
Display display = new Display();
final Shell shell = new Shell(display); //error on this line
* @param args
while(!shell.isDisposed()){
if (!display.readAndDispatch()){
display.sleep();
display.dispose();
Re: newbie: very simple problem strange error [message #167636 is a reply to message #167628] Sun, 27 August 2006 23:16 Go to previous messageGo to next message
You closed the class definition two lines above the declaration for the
Display object.
On 8/27/06 8:29 PM, in article ectke7$o8q$1@utils.eclipse.org,
"3rdshiftcoder" <go@away.com> wrote:
> package bcalc;
> import org.eclipse.swt.widgets.Display;
> public class Foo {
> * @param args
> display.sleep();
> display.dispose();
Re: newbie: very simple problem strange error [message #167644 is a reply to message #167636] Sun, 27 August 2006 23:34 Go to previous messageGo to next message
hi j.michael dean-
it still doesnt compile with the same error.
i tried to make this as absolutely basic as possible this time.
sorry,
jim
package bcalc;
public class Foo {
display.sleep();
display.dispose();
"J Michael Dean" <mdean77@comcast.net> wrote in message
news:C117BC12.16D18%mdean77@comcast.net...
> Display object.
Re: newbie: very simple problem strange error IGNORE SOLVED [message #167659 is a reply to message #167644] Mon, 28 August 2006 00:05 Go to previous messageGo to next message
i think i have eclipse configuration issues.
i started a brand new project and am not using all the old
settings that were correct from the other project.
i will fine tune it and it will probably run right.
sorry again,
jim
"3rdshiftcoder" <go@away.com> wrote in message
news:ecto97$4fv$1@utils.eclipse.org...
> hi j.michael dean-
> sorry,
> jim
> package bcalc;
> public class Foo {
> display.sleep();
> display.dispose();
>> Display object.
Re: newbie: very simple problem strange error [message #167667 is a reply to message #167636] Mon, 28 August 2006 00:54 Go to previous messageGo to next message
thanks J,
i figured it out now.
i forgot to enclose anything outside of main in a method.
+ configuration problems.
my memory is not as good as i'd like.
thanks again,
jim
> Display object.
>> package bcalc;
>> public class Foo {
>> * @param args
>> display.sleep();
>> display.dispose();
Re: newbie: very simple problem strange error IGNORE SOLVED [message #167815 is a reply to message #167659] Mon, 28 August 2006 10:43 Go to previous messageGo to next message
Originally posted by: jochen.wuttke.gmx.de.invalid
If I'm not completely mistaken, what you now posted is not correct either.
You can't have a look outside a methode. Take a look at the Java Tutorial if
you have problems with these basic errors.
> sorry again,
> jim
>> hi j.michael dean-
>> sorry,
>> jim
>> package bcalc;
>> public class Foo {
>> display.sleep();
>> display.dispose();
>>> Display object.
Re: newbie: very simple problem strange error [message #167972 is a reply to message #167628] Tue, 29 August 2006 00:37 Go to previous message
> hi-
> is a huge help.
> thanks,
> jim
> package bcalc;
> public class Foo {
> * @param args
> display.sleep();
> display.dispose();
Do you really mean to have the close curly-brace on line 12?
Wayne
Previous Topic:Perforce plugin?
Next Topic:PDE Build tricks to generate Javadocs
Current Time: Sat Nov 08 01:23:35 EST 2025
Powered by FUDForum. Page generated in 0.07589 seconds
