Home » Modeling » GMF (Graphical Modeling Framework) » SVG images are not rendered in GMF diagrams when I export my RCP product
SVG images are not rendered in GMF diagrams when I export my RCP product [message #167505] Wed, 09 January 2008 11:18 Go to next message
I have a trouble using SVG images in a GMF RCP generated editor. (I use GMF
2.0.1). My SVG images are well rendering in developement environnement
(launching by using the link in the plugin.xml file, for exemple).
But, when I try to run the launcher generated by the "export product
wizard", some red boxes appears instead of these images (or in the same way
by the "launch application" link in the .product file)
I have no exception logged, but I tried to debug the product (using the
debug application link in the .product file), and the problem is located in
the "isSVG" method of the SVGImageType, when we try to create a Document
using xerces.
None the less the org.apache.batik plugin is in my configuration product and
all seems to be alright in this configuration (I tried to add ALL plugins
too).
I see this bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=180675 but I
think I have a fixed version and the trouble only appears in the product
configuration.
Any help ? It's quite urgent (for a delivery).
Fabrice Dubach
Re: SVG images are not rendered in GMF diagrams when I export my RCP product [message #167542 is a reply to message #167505] Thu, 10 January 2008 03:50 Go to previous messageGo to next message
I made a test on the taipan example, and I have the same issue :
Build a product from the gmf rcp editor, test it, and the empty box (which
are made from a SVG image) looks like a red box with a cross dot line.
I don't know if the trouble become from my configuration ? Any help ?
Fabrice Dubach
Re: SVG images are not rendered in GMF diagrams when I export my RCP product [message #167556 is a reply to message #167505] Thu, 10 January 2008 08:45 Go to previous messageGo to next message
Hi, Fabrice,
Did you remember to include your SVG files (or the folder containing them)
in your build.properties?
I know that, for example, the build.properties file of the
org.eclipse.gmf.examples.taipan plug-in is missing the images/ folder from
build.properties, which is why in your deployed instance you didn't see the
empty box. I wouldn't expect the ship image to have appeared, either.
Otherwise, perhaps you are having this problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214410
which I am currently investigating with the help of the Equinox team.
HTH,
Christian
Fabrice Dubach wrote:
> Hello,
> GMF 2.0.1). My SVG images are well rendering in developement environnement
> way by the "launch application" link in the .product file)
> in the "isSVG" method of the SVGImageType, when we try to create a
> Document using xerces.
> and all seems to be alright in this configuration (I tried to add ALL
> plugins too).
> configuration.
> Fabrice Dubach
Re: SVG images are not rendered in GMF diagrams when I export my RCP product [message #167594 is a reply to message #167556] Thu, 10 January 2008 11:11 Go to previous messageGo to next message
Christian,
I do included my images ressources folders in my build. (But it seems that
it is only necessary when exporting my product, but not when using the
"links" in the test section of the product file page.)
I'm not sure I understood the bug that you suggested. (Sorry, but I don't
have a complet understanding of the OSGi technology).
Following you comments about this bug, I saw that my
org.apache.batik.transcoder (v200706111724) is depending on packages which
it itself exports : org.apache.batik.transcoder,
org.apache.batik.transcoder.image.resources,
org.apache.batik.transcoder.keys, and org.apache.batik.transcoder.wmf. Wich
it's quite curious !
I don't know whether this could explain my problem on the product
configuration. How could I be sure ?
Fabrice Dubach
Re: SVG images are not rendered in GMF diagrams when I export my RCP product [message #167618 is a reply to message #167594] Thu, 10 January 2008 11:26 Go to previous messageGo to next message
Hi, Fabrice,
Yes, this is the crux of the class loading problem as reported in that bug:
the imports of the provided packages. The consequence of this problem
ClassNotFoundExceptions on the Transcoder interface.
However, removing these dubious imports exposes further problems that I am
still trying to investigate.
Note, however, that this bug only is manifest when multiple versions of the
Batik bundles are installed. If you only have one
org.apache.batik.transcoder bundle, then you would not have the problem
reported in 214410.
Christian
> Christian,
> Wich it's quite curious !
> Fabrice Dubach
Re: SVG images are not rendered in GMF diagrams when I export my RCP product [message #168058 is a reply to message #167618] Mon, 14 January 2008 11:04 Go to previous message
You were right. I certainly had two installs of batik bundle.
I made a clean install of my Eclipse environnement, and all seems to be ok
now.
Thank you
Fabrice Dubach
"Christian W. Damus" <cdamus@ca.ibm.com> a
Previous Topic:Button in Properties and own
Next Topic:Polygon border
Current Time: Sat Jul 26 09:34:46 EDT 2025
Powered by FUDForum. Page generated in 0.04913 seconds
