Home » Archived » BIRT » Installing BIRT report viewer under Resin
Installing BIRT report viewer under Resin [message #167338] Mon, 05 June 2006 01:39 Go to next message
Originally posted by: baz.spookypizza.com
Has anyone tried installing the BIRT report viewer webapp under Resin?
I copied the birt.war to Resin's webapps directory. After Resin did its
auto deploy, I copied the itext jar to the
WEB-INF/platform/plugins/com.lowagie.itext/lib directory of the newly
expanded webapp. I then copied my JDBC driver jar (jtds) to the
plugins/org.eclipse.birt.report.data.oda.jdbc/drivers directory.
When I open up the webapp in a browser I get the "Birt viewer has been
installed." page.
When I click on the "View Example" link, I get this:
at
org.eclipse.birt.report.service.ReportEngineService.setEngin eContext(Unknown
Source)
at
org.eclipse.birt.report.service.BirtViewerReportService.setC ontext(Unknown
Source)
at org.eclipse.birt.report.servlet.ViewerServlet.__getContext(U nknown
Source)
at
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:113)
at
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:90)
at
com.caucho.server.dispatch.ServletFilterChain.doFilter(Servl etFilterChain.java:99)
at
com.caucho.server.webapp.WebAppFilterChain.doFilter(WebAppFi lterChain.java:163)
at
com.caucho.server.dispatch.ServletInvocation.service(Servlet Invocation.java:207)
at com.caucho.server.hmux.HmuxRequest.handleRequest(HmuxRequest .java:385)
at com.caucho.server.port.TcpConnection.run(TcpConnection.java: 327)
at com.caucho.util.ThreadPool.runTasks(ThreadPool.java:450)
at com.caucho.util.ThreadPool.run(ThreadPool.java:394)
at java.lang.Thread.run(Thread.java:595)
If you need any more information, please let me know. Your assistance
is greatly appreciated.
Thank you,
Barry
Re: Installing BIRT report viewer under Resin [message #167812 is a reply to message #167338] Tue, 06 June 2006 10:35 Go to previous messageGo to next message
Barry,
What version of BIRT did you try this with?
Did you get a log file in th logs directory?
Jason
"Barry Heath" <baz@spookypizza.com> wrote in message
news:e60g00$kpt$1@utils.eclipse.org...
> Hello,
> installed." page.
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> at
> at
> at
> If you need any more information, please let me know. Your assistance is
> Thank you,
> Barry
Re: Installing BIRT report viewer under Resin [message #168016 is a reply to message #167812] Tue, 06 June 2006 16:11 Go to previous messageGo to next message
I apologize for not including that in my original post.
I'm running Resin 3.0.9 and using birt-runtime-2.1RC4.
The logs directory under the birt application is empty. Resin's log
repeats the stack trace I posted previously, but with no other information.
Thank you,
Barry
Re: Installing BIRT report viewer under Resin [message #168770 is a reply to message #168016] Thu, 08 June 2006 23:24 Go to previous messageGo to next message
Barry,
Can you try to rewar the WebViewerExample application and deploying it.
Make sure you have a configuration directory in the WEB_INF/platform
directory.
Jason
news:b754e83d5498dfc9767bc409cebc74ec$1@www.eclipse.org...
> information.
> Thank you,
> Barry
Re: Installing BIRT report viewer under Resin [message #169540 is a reply to message #168770] Tue, 13 June 2006 03:00 Go to previous messageGo to next message
Jason,
I rewar'ed the WebViewerExample and made sure the
WEB-INF/platform/configuration directory existed.
I still receive the same result when I attempt to view the example report:
at
Source)
at
Source)
Source)
at
Source)
at
at
at
at
Any other ideas? Is there more configuration required that I am unaware
of?
Thank you,
Barry
Jason Weathersby wrote:
> Barry,
> directory.
> Thanks
> Jason
>> information.
>> Thank you,
>> Barry
Re: Installing BIRT report viewer under Resin [message #169814 is a reply to message #169540] Tue, 13 June 2006 14:12 Go to previous messageGo to next message
I am having difficulty getting this to work.
Can you try to copy WebViewerExample directory underneath the webapps in
resin and rename it to birt.
This should prevent resin from exploding the war file.
In the browser enter localhost:8080/birt.
Let me know what output you get.
Jason
news:1ff67d0d895601f0ab17a1419c8f5ba2$1@www.eclipse.org...
> Jason,
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> at
> at
> at
> of?
> Thank you,
> Barry
>> Barry,
>> directory.
>> Thanks
>> Jason
>>> information.
>>> Thank you,
>>> Barry
Re: Installing BIRT report viewer under Resin [message #169897 is a reply to message #169814] Tue, 13 June 2006 17:51 Go to previous messageGo to next message
Jason,
The result is the same NPE exception.
Thank you,
Barry
> Jason
>> Jason,
>> at
>> Source)
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> of?
>> Thank you,
>> Barry
>>> Barry,
>>> directory.
>>> Thanks
>>> Jason
>>>> information.
>>>> Thank you,
>>>> Barry
Re: Installing BIRT report viewer under Resin [message #169905 is a reply to message #169897] Tue, 13 June 2006 18:00 Go to previous message
I also forgot to check the stderr from Resin. Here's the exception
reported there:
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at
org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OS GILauncher.java:131)
at
org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:78)
at
Source)
at
Source)
at
org.eclipse.birt.report.servlet.ViewerServlet.__getContext(U nknown Source)
at
Source)
at
at
at
at
at
com.caucho.server.http.HttpRequest.handleRequest(HttpRequest .java:249)
Caused by: java.lang.RuntimeException: Exception in
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start()
of bundle system.bundle.
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:557)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:484)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:275)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:245)
at
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:155)
at
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:503)
at
org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:289)
... 21 more
Thank you,
Barry
Barry Heath wrote:
> Jason,
> Thank you,
> Barry
>> in resin and rename it to birt.
>> Jason
>>> Jason,
>>> report:
>>> at
>>> Source)
>>> at
>>> Source)
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> unaware of?
>>> Thank you,
>>> Barry
>>>> Barry,
>>>> directory.
>>>> Thanks
>>>> Jason
>>>>> log repeats the stack trace I posted previously, but with no other
>>>>> information.
>>>>> Thank you,
>>>>> Barry
Previous Topic:How To Set the dbURL, dbUser & dbPassword dynamically
Next Topic:How to rename PDF generated by Birt Viewer?
Current Time: Wed Nov 05 04:28:06 EST 2025
Powered by FUDForum. Page generated in 0.05030 seconds
