Home » Eclipse Projects » JFace » wrong position of cursor when editing a cell in a table
wrong position of cursor when editing a cell in a table [message #16727] Fri, 26 June 2009 10:00
Hello to anyone,
I have a problem with SWT or JFace and I have posted a message in the SWT
newsgroup :
I try to do something with tables using JFace : When the I type on the
keyboard a letter, the TextCellEditor (and its Control : an instance of
Text) must be in editing mode and the key pressed which is the source of
an event must have its value in the field.
For doing this, the faster way I found is to adapt a little bit the JFace
snippet044 :
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet044NoColumnTableViewerKeyboardEditing.java? view=markup
/* --- start code added --- */
private boolean keyPressed;
private char eventChar;
/* --- end code added --- */
public Snippet044NoColumnTableViewerKeyboardEditing(Shell shell) {
final TableViewer v = new TableViewer(shell, SWT.BORDER |
SWT.FULL_SELECTION);
v.setLabelProvider(new MyLabelProvider());
v.setContentProvider(new MyContentProvider());
CellEditor cellEditor = new TextCellEditor(v.getTable());
final Text text = (Text) cellEditor.getControl();
text.addFocusListener(new FocusListener() {
public void focusGained(FocusEvent e) {
if (keyPressed) {
String myString = String.valueOf(eventChar);
text.setText(myString);
public void focusLost(FocusEvent e) {
keyPressed = false;
v.setCellEditors(new CellEditor[] { cellEditor });
v.setCellModifier(new ICellModifier() {
public boolean canModify(Object element, String property) {
return true;
public Object getValue(Object element, String property) {
return "Column " + property + " => " + element.toString();
public void modify(Object element, String property, Object
value) {
v.setColumnProperties(new String[] { "1" });
TableViewerFocusCellManager focusCellManager = new
TableViewerFocusCellManager(v,
new FocusCellOwnerDrawHighlighter(v));
ColumnViewerEditorActivationStrategy actSupport = new
ColumnViewerEditorActivationStrategy(
v) {
protected boolean
isEditorActivationEvent(ColumnViewerEditorActivationEvent event) {
boolean toReturn = event.eventType ==
ColumnViewerEditorActivationEvent.TRAVERSAL
|| event.eventType ==
ColumnViewerEditorActivationEvent.MOUSE_DOUBLE_CLICK_SELECTI ON
|| (event.eventType ==
ColumnViewerEditorActivationEvent.KEY_PRESSED && Character
.isLetter(event.character))
|| event.eventType ==
ColumnViewerEditorActivationEvent.PROGRAMMATIC;
if (event.eventType ==
&& Character.isLetter(event.character)) {
keyPressed = true;
eventChar = (char) event.keyCode;
return toReturn;
TableViewerEditor.create(
v,
focusCellManager,
actSupport,
ColumnViewerEditor.TABBING_HORIZONTAL
| ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR
| ColumnViewerEditor.TABBING_VERTICAL
| ColumnViewerEditor.KEYBOARD_ACTIVATION);
I have now a problem, the cursor in the field is left positioned and I
would like it right positioned. And I don’t know how to do this. When I
type ‘abc’, the result displayed is ‘bca’.
Should I use other classes?
Thanks for any help.
Maxime.
NB : When a cell is in an editing mode, if I close the window, I get a
org.eclipse.swt.SWTException.
Previous Topic:Changing the focus button in a wizard page or launch tab
Next Topic:A composite on top of another one.
Current Time: Fri Nov 07 21:39:25 EST 2025
Powered by FUDForum. Page generated in 0.03645 seconds
