Home » Newcomers » Newcomers » Diff between IPlatformRunnable, IStartup n preStartup in WorkbenchAdvisor
Diff between IPlatformRunnable, IStartup n preStartup in WorkbenchAdvisor [message #167030] Thu, 24 August 2006 06:35 Go to next message
Originally posted by: joneo_ytk81.hotmail.com
can anybody tell me the usage differents between these 3
IPlatformRunnable, IStartup n preStartup in WorkbenchAdvisor? i tried to
have a login dialog popup when user open the eclipse. i've came across
those 3 interfaces/function but i not very clear about it. can anybody
explain to me? i've tied to do like below but it doesnt popup when i open
the eclipse. can anybody tell me why? am i do it wrongly?
public class LoginDialog implements IStartup {
protected Shell window;
public void earlyStartup() {
MessageDialog.openInformation(window, "Testing", "Early Startup
Testing!!" );
Re: Diff between IPlatformRunnable, IStartup n preStartup in WorkbenchAdvisor [message #167054 is a reply to message #167030] Thu, 24 August 2006 10:13 Go to previous messageGo to next message
Originally posted by: guerreroderrick.gmail.com
To use IStartup, you also need to supply an extension in Eclipse, goto
the plugin.xml, extensions tab, and add a org.eclipse.ui.startup
extension that points to your class.
Guerrero
> open the eclipse. can anybody tell me why? am i do it wrongly?
> Testing!!" );
Re: Diff between IPlatformRunnable, IStartup n preStartup in WorkbenchAdvisor [message #167213 is a reply to message #167054] Thu, 24 August 2006 21:16 Go to previous messageGo to next message
yeah i did that and that's the place where i actually created the class
out and written the example code that i attached along. but it didnt popup
the message dialog box when i test run. pls advice.
Re: Diff between IPlatformRunnable, IStartup n preStartup in WorkbenchAdvisor [message #167220 is a reply to message #167213] Thu, 24 August 2006 21:51 Go to previous messageGo to next message
so now i try implements IStartup in the ExampleActivator and point the
class of the extensionpoint to the ExampleActivator class but it still not
working. can anybody help me?
public class ExampleActivator extends AbstractUIPlugin implements IStartup{
Testing!!" );
Re: Diff between IPlatformRunnable, IStartup n preStartup in WorkbenchAdvisor [message #1506951 is a reply to message #167030] Thu, 11 December 2014 02:30 Go to previous message
Probably it's very late for reply but then this thread help me out and I want to provide the solution as well which might help someone else in future Wink
The reason the dialog box is not showing up is because the shell window which you have created is NULL.
We need to get the Workbench shell handle first and then create the dialog box.
Example to get the Workbench shell handle - http://help.eclipse.org/luna/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Freference%2Fapi%2Forg%2Feclipse%2Fui%2FIStartup.html
Example for creating Username/Password dialog box - http://www.vogella.com/tutorials/EclipseDialogs/article.html
Previous Topic:How do I search for files that contain multiple query strings?
Next Topic:Updating plug-in versions, source, and javadoc
Current Time: Sun Jul 27 13:54:40 EDT 2025
Powered by FUDForum. Page generated in 0.08309 seconds
