SWTBot test [message #1670877] |
Fri, 13 March 2015 07:23  |
Dear Michael.
I want to make some improvements in the Graphiti editor, but i have some problems. I have checked out the project to a fresh installed Luna, setted up an API BaseLine, installed SWTBot. I don't have any error in the projects, but I can't run the SWTBot tests. When I run the AllBotTests.launch configuration, I got the following error:
Exception in thread "Plug-in Tests Runner" java.lang.IllegalArgumentException: Bundle "org.eclipse.graphiti.bot.tests" not found. Possible causes include missing dependencies, too restrictive version ranges, or a non-matching required execution environment.
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.getClassLoader(RemotePluginTestRunner.java:77)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.getTestClassLoader(RemotePluginTestRunner.java:71)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadClass(RemoteTestRunner.java:685)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadClasses(RemoteTestRunner.java:421)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:444)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.main(RemotePluginTestRunner.java:62)
at org.eclipse.pde.internal.junit.runtime.PlatformUITestHarness$1.run(PlatformUITestHarness.java:47)
at java.lang.Thread.run(Thread.java:745)
Do you have any idea about this?
Thank yout in advance,
Krisztián
FUDForum. Page generated in 0.28171 seconds
